Thread: New Construction
    New Construction
    Good evening, new to the site and new to being a pool owner. Well they just started the dig last Friday and everything seems to be going welll with the exception of the weather. Its rained some thoughout the entire weekend and i'm concerned the rain is going to affect the quality of work. Now all they've done is dig the hole and put down some gravel so far and the PB is using a pump to remove any water that collects but its a mess in the back the ground is saturated and is all mud. their suppose to install steel walls tomorrow is it okay to do that even though the ground isnt dry yet? I don't want quality to be sacrificed. I assume the PB knows best but i'm rather cynical of all people but i also know that time is money. Does anyone have any experience with building steel walls on wet ground?
    Thanks in advance.
    18.5x22x40 Lazy L
    Whisperflo Pump 1HP 2 speed
    30,000 gallons
    vinyl
    Hayward Aqua Logic Controller plus
    Cartridge Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New Construction
    Welcome to tfp, rndog43
    I do not have experience with your question, but hopefully someone who does will respond soon
