Results 1 to 11 of 11
Thread: Skimmer leaking
    Skimmer leaking
    Loosing a 1/4 inch or more A day in vinyl in ground pool. We thought our skimmer was leaking so we tore off the deck and found that dirt has settled about 1foot around pool. We dug down a few feet around concrete pad because we thought maybe the leak was in the skimmer pumbing and no moisture. Today I looked under pad and saw where it was wet behind the skimmer wall like the leak is coming from the face plate now where do I start?
    South Central NJ
    3,192
    Re: Skimmer leaking
    Lower the water below the skimmer face. Dry the area. Apply a bead of silicone where the liner and face plate meet and let it dry. Refill the pool and see if that does it.
    How old is the liner?
    Scott
    Owner of - PoolGuyNJ LLC
    Re: Skimmer leaking
    The liner will be 10yrs old in Oct. We live in Missouri. Any special caulk?
    Thanks for the reply.
    South Central NJ
    3,192
    Re: Skimmer leaking
    I like GE Kitchen and Bath Clear. Avoid DAP.
    Scott
    Re: Skimmer leaking
    There are two rusted screws on the skimmer face plate. Do i caulk the screws also? We are hoping for another year or two at most from our liner.
    Thanks for all help!
    South Central NJ
    3,192
    Re: Skimmer leaking
    If its just surface rust, I wouldn't worry. If the screws are tight, they are good. If the skimmer is a Hayward, snap in face plate covers are available and relatively inexpensive. Anderson makes dye filled syringes with a 4" tube instead of a needle for help finding leaks. The tube keeps the hand away and that reduces turbulence. The ink is nearly neutral in buoyancy but does sit. Any leaks near it though will suck in the dye. They are cheap and work better than food coloring.
    If the liner needs replacing, don't wait. The damage water can cause behind the liner will wind up costing you. I had one last year that cost a customer a couple grand additional. He wound up with rusted walls and wash outs in the floor and hopper.
    Scott
    Re: Skimmer leaking
    Bought the GE silicone2 clear it states not for use below the water line. I called and they said they don't have a caulk to remain submersed? Should I buy something else or is this the right one?
    Thanks!
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Skimmer leaking
    Quote Originally Posted by Mom5
    Thanks!
    We use aquarium cement (don't remember the manufacturer's name).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    South Central NJ
    3,192
    Re: Skimmer leaking
    Don't let it cure underwater. The GE silicone is a band aid. You liner isn't far from going in all likelihood so its an easy to remove fix. It should last through the Winter.
    I sort of like the idea of the aquarium tank cement for a potentially long lasting solution but removal after a couple years is a tough thing.
    Scott
    Re: Skimmer leaking
    Thanks. I used dap 100%silicone green tube for aquarium. Still leaking inch since Monday night. Now water level is right above the returns What do you recommend if we are going to put new liner in next year. Inground vinyl so we can't drain. We have a lot of trees. I was thinking about laying solid cover right on water then covering with the loop lock vinyl cover. It has 3 drains on it. We did not get to open until June 16 th this year and the water was black probably from the dirt leaking in the 3 screens. This would keep the fall
    Leaves out and the dirt on top if we don't loose all water from leak.. We live in kc,mo.
    Thanks for your help. I love this site it has gave me confidence and I no longer use the pool store
    South Central NJ
    3,192
    Re: Skimmer leaking
    Are you saying the the water stopped at that height?
    Scott
