Results 1 to 10 of 10
Thread: BBB holds its own after 30 person pool party!
    Jul 2012
    California Central Coast
    74
    My first real test of BBB. We had a 30 person pool party yesterday for 7 hours. Kids, adults; the whole works. All I did was bump up my FC to +3 of it's normal level the night before. By the end of the party, I was a bit concerned. The pool looked cloudy, there were food particles and other junk all in the water. Ick! When everyone was out of the pool, my FC had dropped to 4.5, which is at the low end for my CYA, but still okay. I bumped up the FC to 6, and let the filter run all night. This morning, I awoke to this! The pool was right back to crystal clear. All readings are ideal. Go BBB!
    Test Kit: Taylor K-2006
    Pool:In ground/Pebble/16,000 gal/Cartridge Filter/Pool Built appr. 1995-2000
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: BBB holds its own after 30 person pool party!
    Sep 2009
    Greentown, IN
    914
    Awesome !
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Aug 2011
    Central Valley California
    121
    Sounds like a fun party. Glad the pool held up.
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Folks what's a BBB? Forgive my noobiness...
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    38,290
    Quote Originally Posted by Azmp1
    BBB is the nickname for our method of maintaining a pool. Stands for bleach, borax, baking soda. The idea is to understand the pools chemistry through accurate testing and only put in your pool what it needs. And knowing that the bbb chemicals are the same as most chemicals sold in pool stores but available for less money.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Got it. Thanks. Need to read the stickies!
    May 2012
    Dover, DE
    13
    I'm glad it held up
    Apparently I'm expecting 50 guests two weekends from now and was trying to research now how I should prepare for it myself...especially for the aftermath.
    Did you have any issues with Ph rising too high through the day?
    I was going to make sure my Ph levels were at the low side (7.3'ish) and the FC as you did (+3 normal value) at the begining of the day before the carnage.
    My mind is more at ease now...
    29,800gal, sand filter, IG, vinyl, 2.0HP Hayward Ecostar Pump, SWG (AquaRite T Cell-15)
    Jul 2012
    74
    I had the PH at 7.8 (high end because of the bump with bleach I guess) before the party. After the party it was 7.4. I'm assuming that it dropped because as I understand it, as chlorine is cosumed, the PH increase that the bleach initially causes is "negated" and the PH drops back down. Someone correct me if I'm wrong. =/
