Results 1 to 15 of 15
Thread: My doctor is absolutely opposed to chlorine
    This all misses an important point. Though chlorine is easier, and baquacil can be a pain (as well as expensive), my doctor is absolutely opposed to chlorine use for health reasons. If salt were an option for us, we would consider it. I am hoping to learn more about some other non-chlorine options that may work, be acceptable to my doctor, and be easier than baquacil. Until then, I'm stuck with baquacil.
    Sh. Burke
    Re: My doctor is absolutely opposed to chlorine
    Welcome to TFP!
    Nearly every single problem with chlorine is the result of CC levels in badly maintained indoor pools. Properly maintained outdoor pools almost never have any of those problems.
    There are only three options: chlorine, bromine, and baqua. Bromine is somewhere in-between chlorine and baqua in both expense and problems, though most people who have real (rather than imagined) problems with chlorine will have the same problems with bromine that they have with chlorine.
    It is possible to manage baqua on an ongoing basis if you replace your filter media and half of your water every year. The costs remain high, but at least replacing the filter media and water gets rid of the worst of the problems.
    By the by, salt systems have chlorine in the water just like regular chlorine pools. The salt system makes the chlorine as needed instead of chlorine being added manually.
    38,301
    While they may be a doctor, they are petty ignorant regarding pool chemistry.
    Unless you have well water, there may be more chlorine in your tap water.
    Another thing to realize is that a private pool with stabilizer had a much lower active chlorine level than public pools. There is a lot of information here regarding the chemistry.
    Also realize that a salt water pool is a chlorine pool.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by Chris111
    time for a new doctor?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Where theY specific as to their objections? I am curious as to why a regular Md would be so against chlorine. It's not as if you are ingesting the water on a regular basis.
    Nov 2012
    9
    why is salt not an option for you? Does your doctor recommend that because of a skin issue?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    A salt pool is a chlorine pool.
    Nov 2012
    9
    I did notice that you said Health Reasons so void my question,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    I don't know why he would be - he washes his hands in tap water that is way higher in unstabilized chlorine. Unless he has invested in some miracle-pool-system manufacturer...
    Center for Disease Control is a big fan of Chlorine:
    http://www.cdc.gov/healthywater/swimming/rwi/index.html Maybe the doc just wants to drum up some business treating skin rashes, urinary tract infections, and whatnot.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Without knowing the specific objection it is hard to advise. The only real option may be baquacil.
    Feel free to give more info and ask more questions...
    Sent via Tapatalk...
    38,301
    This is the OPs only post from over 3 months ago ... pretty sure they are no longer around since there has been no response.
    Jun 2012
    Mint Hill, NC
    2,589
    Ack... With tapatalk it is harder to notice the dates...
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    I can't help wondering what the doctor swims in
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    as a physician myself I am often embarrassed and disappointed in some of the ignorance of my colleagues.
    32000 Gallon 18'X40' Rectangular Gunite pool. Pentair 60sqft DE filter. Electric heat pump. Aquamatic Pool Cover.
    38,301
    Quote Originally Posted by bolleat
    I feel the same way about fellow engineers when I come across some ridiculously stupid design ... you know like all modular furniture instructions
