Results 1 to 11 of 11
Thread: Feedback from first 3 months of using BBB method
    first year using TFP advice and a K2006 test kit - previous 14 years only tested for Chlorine and PH - and used the Frog system.
    this year, no frog system expensive stuff and all key levels based on TFP recommendations.
    Water quality this year is best ever so far, only adding 2 to 3 gallons of bleach per week and still keeping FC at 3.0, but I do use a floater with trichlor tabs just to be safe. I only shocked once this year to open. In previous years I was shocking weekly, using lots of chlorine powder but I probably had CYA levels of zero. I am assuming my CYA of 40 to 50 is protecting my FC from burning up in the sun.
    current levels 8/12
    FC = 3.0
    CC = 0.0
    PH = 7.5
    TA = 260
    CYA = 52
    Water Temp = 80.
    I have to get FC up to 4.0 per the Chlorine/CYA chart, but should I be concerned about lowering CYA? or is this almost ideal?
    24K gal, plaster, concrete decking, cantelivered coping, 20 years old, raised attached stone spa - 1 1/2 HP purex triton pump, 3 yr old 48 sq ft Pentair DE filter with multiport, Polaris 380 w/pump, 2 yr old Pentair mastertemp 400k heater - live in southeastern PA outside phila.
    30,400
    Re: Feedback from first 3 months of using BBB method
    CYA around 50ppm is fine but you are continuing to add CYA by using the pucks.
    I'm not sure what you mean when you say you are using them "just to be safe".
    I guess I am afraid of FC dropping if I don't test for couple days.
    in your opinion, would I be better off not using the pucks, because they increase the CYA levels? just stick with liquid bleach and occasional powder (I have left over powder from last season)
    Apr 2012
    SW Ohio
    456
    i would just use bleach no powder or pucks they will continue to add cya and 50 ppm for a non swg pool is about perfect, what i do is test mine every evening about 8:30 pm and i add enough bleach to bring mine up to 8 ppm which is a couple above my target per my cya of 50 and by the next night with all day sunlight and moderate swimmer load i lose between 2 and 3 ppm which is still plenty safe above my 3 ppm minimum, but all pools are different, that works for me and i have never had a problem......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    As Fastchev and duraleigh said, do not use any more pucks.
    Quote Originally Posted by jp4120
    What is the powder? Is it dichlor or calhypo? If calhypo, what is your CH level?
    my CH is 260 - and the powder is Leslie's power powder plus so its Cal Hypo.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Since you TA is high, even though your CH is not too bad, I would stop using the calhypo. See: http://www.troublefreepool.com/pool-...alcium_scaling
    Teedback from first 3 months of using BBB method
    I listed my TA too high in a previous post.
    here are the correct measurements.
    TA=70, CH=260, CYA=50
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Oh, that is better
    Then just keep track of your CH since you will add to it every time you use calhypo. Our commendation is 250-350 ppm CH for plaster pools (but of course other parameters can play in here...see the link I posted above).
    started using liquid bleach only, no powder or pucks.
    first year using BBB method - with great results, usually have green algae spots by mid Aug, and this year no algae yet.
    wondering if my liquid bleach usage is typical or better/worse, seems great to me, I used to shock weekly plus use the frog system.
    1.42 gallons about every 2 days (half bottle each day) for 27/28,000 gallon pool. so about $10 / week for chlorine., this keeps my levels between 2 and 4/5 - also haven't shocked all season (4 mth season 5/15 to 9/15)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Your chlorine usage seems reasonable to me
