Thread: I did something wrong.. Someone help me figure out the math
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    I am in the shocking process and running out of r0871 so I saw a thread that said I could use 5ml sample (but not for overnight) and multiple by 2
    BTW I already placed a order on TFTest to get the big bottle.
    Here is what I did (and I am sure I messed up)
    7ml distilled water
    7ml pool water
    shaken
    tested at the 10ml line (didnt use 5ml)
    put in 27 drops before it turned clear.
    So is it even possible to figure out what my FC is ?
    I dont want to run again until the morning
    Any help please.
    Thank you
    14500k inground, vinyl, built in 2007
    Hayward Sand Filter, 1hp Hayward pump, AquaCal electric heat pump
    Taylor K 2006
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: I did something wrong.. Someone help me figure out the m
    Since you diluted your sample by 1:1, the math is:
    27 drops * 0.5 ppm/drop * 2 = 27 ppm FC
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Thank you.. that was the number I came up with.. but then I started overthinking it because I used 10ml instead of 5ml
    I guess the 5 ml was just to save on reagent.. which is what I was trying to do.. I totally screwed that up...
    Thanks for the speedy reply
    Taylor K 2006
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You bet...you still ended up saving reagent since you would have put in 54 drops if all 10 ml was pool water.
