Thread: OPPS---FC too high.....
    Had a bit of a brain fade.... Brought my pool up to ~30ppm FC due to some "dull" water.. Used 6% bleach and all was well. Check next day and it was ~32ppm.. Dummy me, forgot to turn off the SWG and reading ~26ppm this evening. CYA is ~65ppm. I know that below shock level is safe to swim, but, CYA chart say shock is ~26 and the poolcalc says shock is 20ppm. Don't think it will burn off much with tomorrow morning sun, but want to swim with a few friends tomorrow. What would you do???
    Thanks as always!!!!
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Jul 2009
    Olney, MD
    218
    Re: OPPS---FC too high.....
    Here is another person's experience with sodium thiosulfate (reduces chlorine).
    http://www.troublefreepool.com/never...it=thiosulfate
    Another option is to...um....okay...uh..... pee in the pool. I have a lot of infant/toddlers in my pool. Despite requiring "swim diapers" and such, they reduce my chlorine levels significantly....
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    LOL..well THAT is an option and will do my best to "encourage" everyone to do the same. Guess I picked the wrong week to stop drinking.. Any other solutions/input???
    Jul 2009
    Olney, MD
    218
    Before taking "drastic measures", I would check the chlorine again a few hours after it gets some sun. If you have a cover, leave it off tonight or get up very early and take it off. The chlorine at such high levels will drop a lot faster than at a normal FC. It might only take a few hours of sunlight to knock your number down significantly (at least to below 20, which would be fine for swimming).
    Butterfly's Avatar
    South Carolina
    10,045
    With CYA about 65, I'd swim when the FC drops below 26
    Make sure the SWG is still OFF!
    You're done SLAMing when:
