Thread: About to break ground on pool have well
    May 2012
    Oconee, Georgia
    82
    I have a well water question. I know I have some iron in my water how do I check the iron level in my water?
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: About to break ground on pool have well
    Pool stores and softwater conditioner stores often will do it.
    You can also buy a kit, but iron test kits are expensive. Here is one from tftestkits: http://tftestkits.net/K-1716-Taylor-Iron-Test-p30.html
    Yukon Jack's Avatar
    May 2011
    Rose Hill, KS
    94
    Be sure to also check the hardness. My well water terrible and at some point soon I plan to dump and start over with water from our city line.
    18x33 AGP, 17,300 gal, Hayward Sand Filter, 1.5 HP 2 Speed Hayward Pump
