Thread: Hayward Navigator goes and stops
    We have a pebble-tec pool and just got a completely rebuilt navigator. I saw it working in the guys non pebble-tec pool. We try it in ours and it will go for a few minutes or so and then stop or go real slow. We even cleaned the cartridge filters. One thing of note is that the Bottom Collector Manifold is broken in a spot so unfiltered water is getting through, but not sure if this has anything to do with the cleaner.
    The suction lever is in the correct spot. What else can I check? There are no obstructions visible.
    edit: now it just doesn't go at all.
    Derek
    Re: Hayward Navigator goes and stops
    New feet, new wings on my navigator, tried all three settings on the side and it still gets stuck....next step - replacing flaps.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    I'm not sure exactly which model you have (I have the Navigator Pro), but maybe the design's are similar (Mine used to stop / clog with the slightest bit of sand). I suggest you increase vacuum pressure (suction). You may have to restrict some from the skimmer and/or main drains to accomplish this. If you have the guage that came with it (measures vacuum), I've found that about 1/8" beyond maximum indicator line is perfect. Once the A-frame bearings loosen (break-in), you can lower the vacuum pressure slightly. Heres a thread with all my Navigator rantings and drama
    http://www.troublefreepool.com/haywa...ed-t54877.html
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Replacing the A-frames fixed this. Here's the thread with my fix if someone finds this thread first.
    http://www.troublefreepool.com/navig...ilit=navigator
