Thread: Starting up SWG, adding salt, TDS, help!
    Hello,
    I have been happily on the BBB system for the past year and a half and am so happy I had found this site...never had any pool issues, and been adding bleach and testing daily. I decided to bite the bullet and order a new SWG cell (previous owners had existing SWG system but cell had died). Before I added the salt, I used salt test strips to test my salt ppm, and measured 1600ppm. This seemed high to me since all I had added since my drain and refill 1.5 years ago was bleach, so to double check my reading I took my sample into the dreaded pool store, where the feedback I received was "TDS is way too high, you must drain your pool or a SWG system will not work properly." I took it with the grain of salt that I use when I go into pool stores, and walked out, but forgot to ask what my ppm level of TDS actually was. My question is:
    1. Is adding 1-2ppm of bleach every day for the past year and a half enough to raise my salt levels to 1600ppm?
    2. If yes to #1 above, to bring my salt level to 3500ppm, would I just add the equivalent of 1800ppm (3500-1700=1800)?
    Here are my pool stats:
    12000 gal
    3ppm FC
    0ppm CC
    280 CH
    60ppm CYA
    7.4 pH
    92 deg F (live in AZ)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Starting up SWG, adding salt, TDS, help!
    50 ounces of bleach (to raise your FC by 2 ppm) adds 3.3 ppm salt to your 12000 gallon pool.
    3.3 X 365 X 1.5= 1806 ppm salt...of course you have had splash out and you may not be maintaining the pool 365 day/year...but you have added a lot of salt.
    As you already know, ignore TDS. By the way 1600 of the number they measured is salt.
    Quote Originally Posted by azxd09
    Yes. 3500-1600=1900 ppm salt to add.
    Thank you for the response! I feel much better now.
    It is usually best to add less than the full amount of salt to avoid overshooting the target level. I would suggest targeting about 500 ppm lower than the target. If your salt system has a salt readout, check that first before adding the final amount of salt.
    Support the site
