Results 1 to 10 of 10
Thread: Dead Mice - Any real impact?
    So I just fished out the third dead mouse from the pool. I had just been down to the pool and so this guy was only in the water for a few hours. Is there any real impact on the balance for these little guys?
    I have been chasing an algae problem and thought I was on the mend when this guy showed up.
    My current readings are:
    FC 11
    CC <.5
    CYA 70
    CH 320 (ish)
    PH 7.5
    TA 120
    My FC is high because I am coming off of a couple of days at shock level (28).
    Jim -Nebraska
    12,000 Gallon, Vinyl In Ground
    Filter Flow Rate 120GPM, 3/4 HP pump
    Pool Built 1973
    38,548
    Re: Dead Mice - Any real impact?
    Did you pass the 3 tests tip so the shock process?
    Regarding the mouse, would not hurt to bump back up to shock level again ... May not really be necessary though.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    I doubt it, FC is high enough that any nasties he might have put in the pool are gone.
    because of my CYA shock level is kindof expensive to get to ( 28 fc ) so I am not expecting to go back up. that said I am still showing a little algae growth on the sides of the pool.
    Jim -Nebraska
    Pool Built 1973
    Most animals are not a serious health risk. Raccoons or pre-weaned calves and lambs can be a health risk. See the following page for more information.
    http://www.cdc.gov/healthywater/swimmin ... pools.html
    Support the site
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Good to know. Mine are still alive!
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Mar 2012
    Amarillo, Texas
    341
    At least they weren't 3 blind mice? And they didn't chase your wife?
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Jun 2007
    New Jersey
    653
    My pool is on the edge of a hayfield and my seasonal dead mouse count averages around six. Unless I've been away and the corpse has bloated I never do anything. We've been at this in the same location since 1946 (before I was born.) I do check my skimmers daily if I'm not away.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    Quote Originally Posted by Durk
    Would love to see pics of your original pool!
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    Oct 2007
    Cedar Hill, TN
    252
    Quote Originally Posted by watermonster
    Sorry to read and point out this part of your comment. You might not be done shocking.
    How about draining some of your water to get that CYA in better range?
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
