Thread: Ring around the tub.....er, pool
    Hi to all;
    We have what looks like lime deposits all around the pool at the waterline and above. Tried some "Lime Away" and it cleans it quite weel. Just wanted to be sure that it won't harm anything else. Probably won't use enough to change the chemistry.
    Thanks for any suggestions.
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    38,532
    Re: Ring around the tub.....er, pool
    Many people just use a muriatic acid and water solution to help clean the white line ... Not sure what is in the lime away
    Either way, the impact to the chemistry is likely low.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Sep 2009
    Greentown, IN
    914
    I use a magic eraser... works great!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Juat a note say that Lime Away worked great on the lime deposits with some brushing.
    Garyr R.
