Results 1 to 7 of 7
Thread: Alternative to the needle or ball valve for the liquidator
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Just thought I would pass this information along. I installed one of these pinch valves http://www.usplastic.com/catalog/item.aspx?itemid=29062 yesterday in place of a ball valve. So far it looks to be as good as a needle valve for a heck of a lot less money. The 3/8" size is less than $10. Since it slips over the tube there are no connections to leak. I get as good of control over the flow as I did with $50 needle valve that started leaking.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Alternative to the needle or ball valve for the liquidat
    Nice find!
    And it won't clog - I wonder if the tube will; however I'd guess that after you open it up and move it around the clog would be released.
    May 2012
    Allentown, PA
    219
    Keep us posted on how well that thing works. Sometimes simple is the best method for solving problems. Thanks for sharing!
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    After three days it just sets there and does what it should. I've run it up and down numerous times from shut off to full open and there were no surprises. I guess it's possible to get a clog like any other valve, but in this case you could see it and tubing is cheap and easy to replace if it came to that. Here's a couple of shots of the set-up.
    [attachment=0:2z7rsx0s]pinch valve close.jpg[/attachment:2z7rsx0s][attachment=1:2z7rsx0s]lq pinch valve.jpg[/attachment:2z7rsx0s]
    May 2012
    Allentown, PA
    219
    I ordered mine today thanks.
    May 2012
    Allentown, PA
    219
    stev32k,
    You might want to try to lower the flow meter below the top of the LQ. I lowered mine and it seemed to stop air bubbles from getting above the ball on the left side of the flow meter. In turn, it should help regulate your flow better without air bubbles.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Okay thanks, I'll give that a try.
