Thread: Automatic Pool Cleaner Keeps Getting Stuck
    Hey all,
    I recent had a pool installed, and I went with an automatic pool cleaner over popups. I have owned several houses with pools and have used both options, and I've found that an automatic pool cleaner works almost just as well as popups (save the steps), so I went with the economic approach. My problem is that with the new drain systems, my pool cleaner is ALWAYS getting stuck on them and not doing its job.
    The cleaner runs into the protuberant drain covers and just sits there. Occasionally it frees itself, but in the 8 hours I have the pump timed to run, at least 75% of its time is stuck on one of the drain covers.
    Is there something I can do to prevent this from happening? Maybe some sort of an attachment to the drain or the cleaner which will help it navigate around them? Maybe a new drain cover?
    If it helps, the drain covers and cleaner are both Haywards. The cleaner is the Navigator series.
    In-ground pebble tech pool and spa. Cartridge filter pump. Chlorine sterilization. In-floor cleaning. Waterfall. Spa jets. Jandy pumps. Jandy Colors lights. Jandy control box with iLink PDA v3.
    Jul 2012
    Illinios
    10
    Re: Automatic Pool Cleaner Keeps Getting Stuck
    I have the same problem! Except mine runs while I'm at work everyday. Every night I come home, it wedged itself in the stairs in the deep end of my pool. Totally frustrating. I can't think of anything easily removable that I can build or put around the stairs? Good luck
    2004 - 36'x18' 26000 Gallons - IG-vinyl, Hayward 244t sand filter=300lbs, Jandy HP plus 1-1/2hp pump, Jandy LX-400L heater, Jandy AquaPure1400 Chlorine Generator (salt), Polaris 480 robot
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    No idea if they work: Smart Ring Drain cover - http://www.electricmotorwarehouse.com/p ... CFMQgwgwAA
