Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: How do I backwash my filter? Do I add DE afterwards?
    May 2012
    Austin, TX
    140
    Hello - I can't figure out how to backwash my filter. It has a valve with a large handle that can be pressed and turned. There appears to be a pipe going into the ground for the "waste" option. There is a sight glass. I can't find a backwash hose or a waste valve - not sure what that is. Is this what I do?
    1. turn off filter
    2. turn valve to "backwash"
    3. run for a minute
    4. turn off filter
    5. turn valve to "rinse"
    6. turn off filter
    7.turn valve to "filter"
    8. Do I add DE?
    I have a
    1.5HP Hayward Super Pump
    Hayward 4820 DE Filter,
    Maybe there is a post or a link to website that shows me how to backwash?
    David
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: How do I backwash my filter? Do I add DE afterwards?
    I think this is the manual for your filter: https://www.hayward-pool.com/pdf/manuals/Manual362.pdf
    If there's a pipe marked waste, it probably got plumbed into the sewer somewhere. If there's an open pipe sticking out somewhere in all the valving, you'll need a backwash hose to direct the waste water somewhere.
    Yes, you'll need to recoat the grids with fresh DE.
    There are a number of videos on youtube showing backwashing.
    May 2012
    Austin, TX
    140
    Thanks Richard - I did try the manual - it is a little confusing. I can't find the backwash outlet on the valve - I'll keep digging.
    How do I know how much DE to add?
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by Drockfresh
    There's going to be 5 ports on the valve. 2 go to the filter itself. One comes from the pump. One goes back to the pool, maybe through the heater first. The fifth is the backwash outlet. If it disappears into the ground and is labelled waste, that's almost certainly it.
    Page one of the manual gives capacity. It says 6 lbs, however that is for an initial charge. It never rinses completely. Conventional wisdom says 80%. So 4.8 lbs of DE needs to be added.
    May 2012
    Austin, TX
    140
    Thanks again - the fact that I don't have to attache a backwash hose - that the pipe is plumbed was throwing me off.
    So - the filter was backwashed and no DE added - and then filter was run for a few weeks - is this a serious problem -
    or can we just add DE and go on our way?
    Would you backwash first and then add the DE or just add the DE to the skimmer?
    Thanks!
    David
    Richard320's Avatar
    Jan 2010
    19,009
    Thanks!
    David
    You better backwash first. No telling what's stuck to the grids now. Ideally you'd tear the filter apart and manually clean the grids 100%, then you'll know for sure what the clean pressure is. However, not everyone has mechanical aptitude.
    38,301
    Running the filter without DE can clog it up pretty good if you water was dirty and backwashing may not help.
    I would recommend at this point breaking the filter down and spraying down the grids very well to get them clean, then reinstall, and coat with DE.
    Note for backwashing it is good to do the backwash/rinse cycle a few times until the water is pretty clear on backwash. After a backwash, I usually only add about 80% of the normal DE amount as a lot is left in the filter after the backwash. Also some people do the recharge of DE while on Rinse so no DE makes it to the pool, but I have never had that problem.
    Finally, it is a good idea once a year to fully break the filter down and clean everything to start fresh. Some recommend a soak in a soap solution followed by a soak in an acid solution to remove any build up on the grids.
    Jun 2011
    Long Beach, CA
    2,788
    It all depends on how long the filter has been running without being taken apart and fully cleaned. When I was running DE, now I use Fiber Clear, I would take the entire filter apart 2 times a year. I would first backwash the filter and then take it apart. My filter has a 6 pound capacity and I would add 4 pounds after backwashing. When I took the filter apart after backwashing I was amazed at how much DE was still remaining. I would backwash for 2 minutes, run in filter mode for a minute, backwash for 2 minutes, run in filter mode for a minute, and then backwash for another minute.
    Personally I would take the filter apart to inspect the condition of it and you would know for sure that you have the correct amount of DE in the filter.
    Jblizzle just posted before me with similar suggestions but I will add my $.02 anyways.
    May 2012
    Austin, TX
    140
    Oh man - and I just had the filter professionally cleaned last month.
    If the water has been clear and looks clean - does this make the case for not having to take apart and clean the filter again?
    David
    Jun 2011
    Long Beach, CA
    2,788
    Do you know what your clean filter pressure is and what it is right now? Also, what did the pressure get up to before you backwashed? Do you know what the professional cleaning included?
    Richard320's Avatar
    Jan 2010
    19,009
    David
    How could it have been professionally cleaned and not recharged with DE? That doesn't sound professional!
    Why do you want to backwash if it's only been a month, anyway? Were you clearing a swamp?
    May 2012
    Austin, TX
    140
    Quote Originally Posted by ping
    I don't have any of those numbers
    Jun 2011
    Long Beach, CA
    2,788
    If I was you, I'd backwash it one more time, take it apart and clean it with a hose, and then recharge with the proper amount of DE. Note the pressure and you will have a clean baseline to start from.
    May 2012
    Austin, TX
    140
    Quote Originally Posted by Richard320
    David
    Yes, the pool company did add DE. The water has been very clean. When I figured out the chemicals and the vacuuming, I stopped paying them for the weekly clean because I could do it myself (and the cost was $$$$ and there were few other things about them) . I decided to have them clean the filter because I didn't want to do that myself. I think they were backwashing each week - so when I took over - I backwashed once (without checking the pressure) - but did not add DE - ROOKIE MISTAKE - then I decided to post about it here to see what to do - the question is - how do I get everything under control?
    The pool has been clean and the numbers stable - however there have been some dust-like particles floating on the surface.
    I just backwashed correctly and added the DE. What can I do to make sure 100% everything is under control?
    Hope things aren't messed up too bad
    David
    May 2012
    Austin, TX
    140
    Arghhh- Looks like I'll have to clear my afternoon schedule
    Actually, I will probably just hire the pool company to clean the filter again on Monday.
    What a mess
    Thanks for the heads up
    Jun 2011
    Long Beach, CA
    2,788
    Since you just added the DE, run it as is and keep an eye on how your water looks. Dust floating on the surface wouldn't bother me too much right now, but if you notice that your water isn't what it used to be then I'd go ahead and take the filter apart and clean it. The next time that you need to backwash, do take apart the filter so you know that you are starting from a nice clean filter.
    May 2012
    Austin, TX
    140
    Whew - thank you - I like this advice. The pool looks clean so I wait until next time to get the take apart and clean the filter.
    May 2012
    Austin, TX
    140
    OK, so I finally had time to get the filter cleaned and recharged with DE.
    A picture of the gauge is below - what will be the next time I backwash?
    Thanks
    38,301
    We say backwash at a 20-25% increase. So that would be around 12-13psi.
    BTW: I deleted your duplicate post as it is answered here.
  20. Back To Top    #20
    May 2012
    Austin, TX
    140
    Got it .. Thanks. But what are the white and green dials for... ?
