Thread: No power
    No power
    I have a new (3 weeks old) Aquarite chlorine generator (T cell 9). This morning I noticed the pool looked slightly cloudy. Figuring all the rain lately had something to do with it I thought I would switch it to Superchlorinate and shock the pool. When I opened the cover, there were no lights on. I checked the ground fault circuit and tripped and reset it to be sure. Still no power light on the unit.I can feel some heat from the transformer, so I know it is getting power, but nothing elase shows signs of life. I have read the posts about tghe curent delimiters going bad. Obviously, with a new unit, it looks brand new, not burnt or cracked. Could it still be this item? Any other suggestions? (By the way, it is powered by a circuit we thought swithed on and off with the pool filter. Found out that it has been powered up the whole time. I am correcting that this morning.) Any help would be appreciated.
    38,251
    Re: No power
    Welcome
    Not sure about the power issue, but suggest you review Pool School ... specifically Shocking Your Pool
    We do not recommend using the SWG for this process as it adds the FC too slowly and potentially reduces the life of the cell.
    Re: No power
    Thanks. I added some shock this morning.
    38,251
    Re: No power
    Please define "shock" for us ... likely the use of any powder chlorine is a bad idea (although that is an assumption as you have not posted any test results).
    How did you determine the amount to add? What is your stabilizer level, which determines your FC shock level?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: No power
    It could be this problem: www.nocellpower.com
    Pretty common with Goldline units.
    Mark
