Thread: Lowerin pH with Dry Acid
    Mar 2012
    London, ON CDN
    42
    I have a quick question that relates to the topic instead of starting a new tread on the same subject. I was also using dry acid to lower my PH and then switched to MA. I was able to get my PH down easy enough but I went from a TA off 110 down to 80ppm now.
    Does Dry acid lower the TA the same as MA does? I am using 12% bleach to sanitize with which keeps pushing my PH up. So I am having to constantly added acid every now and then. I guess I should bring my TA back up a bit too while I am at it?
    Current Results
    CL 3
    CC 0
    PH 7.4
    TA 80
    CH 180
    CYA 30
    21K gal, Vinyl, 16X32, 3/4 HP Hayward Maxflo, Hayward Pro 24" Sand Filter
    Apollo Pools (Canadian Supplier for Taylor Kits) www.piscines-apollo.com
    38,262
    Re: Lowerin pH with Dry Acid
    According to poolcalculator, the dry acid lowers the TA slightly more than MA for the same pH change.
    Your pH ids rising due to the liquid chlorine which is basically pH neutral. Any aeration in your pool, will cause the pH to rise.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    MA and Dry Acid both work to lower TA.
    TA of 80 is fine for Vinyl but eventually you'll need to add more if it drops too far.
    Mar 2012
    London, ON CDN
    42
    Thanks for the quick replies.
