Thread: Ladder help
    Ladder help
    Hello
    We have the Intex 16x48 ultra and using the ladder that came with it.
    I have a ladder from when we had our big 24x52 from Recreational Factory Direct that we got back in like 98 or so.
    (Pic attached)
    I cleaned it off and went to use it then remembered why we didn't use it much. The legs float up and it won't stand up by itself.
    I had to put some of my dive weights in the bottom to keep it down.
    I'd like to use this instead of the cheap ladder but need a way to weigh it back down. The weights are long gone.
    Any ideas.
    Thanks
    Mark
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Ladder help
    drill a hole and fill it up with dry sand or pea gravel
    sometimes I think there is a spot for bricks to be put inside
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jun 2012
    Glen Burnie, MD
    38
    Re: Ladder help
    Our ladder had the holes towards the top and bottom. I just dunked and allowed it to fill with water.
    8000 Gallon 18' Round 52" Deep Morada Pool (Namco) DE Filter
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Ladder help
    SOme people get a couple lengths of schedule 40 pvc, glue a cap on one end, fill with sand or gravel, glue a cap on the other, and you've got a cheap water proof weight. Just have to fix it to the ladder.
    2 or 3 of those should work.
    Jun 2012
    Glen Burnie, MD
    38
    Re: Ladder help
    Quote Originally Posted by cramar
    That's a great idea.
