Thread: TF-100 Test Kit Q
    May 2012
    NC USA
    92
    TF-100 Test Kit Q
    Hi,
    So when doing the TA test with the test kit it seems that my color switched to pink, not red as the directions suggest. Should I stop adding regent at the bright pink color and call that red? Mine doesn't seem to ever get to red. I was at 30 drops the other day- today I'm at 14 drops and it is just bright pink. Advice?? Will it ever actually turn true red? It seems like I will use the entire bottle to run one test if I am truly waiting for a "red" color.
    Thank you!!
    13 x 29 IG fiberglass pool-
    Waterways pump-Jandy Cartridge filter-Salt system- TF100 Test Kit-
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    Re: T-100 Test Kit Q
    I've never gotten true red either - just pink. I'm not an expert - but I usually just stop counting when the color stops changing. Pink is a red in my book!
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    May 2012
    NC USA
    92
    Re: TF-100 Test Kit Q
    Ok, Thank you Coffeegoddss! I appreciate the feedback.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,113
    TF-100's YouTube Page
    Take a look at the videos on YouTube. The main part you wanna watch for is when it stops changing colors. If you add 2 drops and the water stays the same pinkish red.....subtract those 2 drops and there's your end result.
    May 2012
    NC USA
    92
    THANK YOU Leebo!
