Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Did my refill today
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Did my refill today
    Ok.. so they came today and added back the 7200 gallons of water that we took out last night (about 1/2 the volume)
    Pool is still cloudy. but I can now see the bottom in the shallow end
    Here are my current numbers
    FC .5
    CC .5
    PH 7.3
    TA 100
    CYA 80-90 hard to tell. did the test twice
    So I am going to go to Shock level of 35 just to be safe Right ?
    and I need to bump my PH up according to pool school and calculator 43oz borax
    My question is.. do I add the Borax first ? how long should I wait to add the bleach?
    14500k inground, vinyl, built in 2007
    Hayward Sand Filter, 1hp Hayward pump, AquaCal electric heat pump
    Taylor K 2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Did my refill today
    Leave pH right where it is. 7.3 is great. Get started on the bleach NOW.
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Ok.. I am going out right now to add it. Then I am going to the store and buying somemore... since I will be home I want to do the overnight test tonight and then keep it up to shock level all day tomorrow.. and see if I still lose fc tomorrow night. Does that sound like a good plan?
    Taylor K 2006
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Ok.. I am back.. One more question. I added the bleach at 5pm today.. Now I cant see the bottom. Is that normal?
    Taylor K 2006
    38,271
    What does the water look like? Besides not clear.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    New To the BBB First Shock process
    [Moved by moderator - try to keep related posts together. Thanks, jblizzle]
    No I am confused. Here is my senario
    CYA was at 160 dump 1/2 water and refilled today. 4pm it was at 80-90 (very cloudy here today and hard to read)
    I could see the bottom of the shallow end but not deep
    levels were
    FC .5
    CC .5
    PH 7.3
    TA 100
    CYA 80-90
    So I started the shock process (added 4 gallons 12.5%) and then at 8pm
    FC 27.5 (added another gallon)
    cc 0
    My confusion comes more from the pool calculator vs CYA/shock chart
    pool calculator says shock level 20 based on cya.... cya chart says 35
    Which should I be using? I really dont want to bleach out my liner anymore than it is. I am afraid if I keep it at 35 that will happen
    Should I continue to check as late as possible? Is it ok to do FC in the house light (using taylor 2006)
    I also wonder if it is normal that now my pool looks like milk and I cant even see the bottom of the last step.
    I am sure you all have more advice for me. Thanks again.
    Taylor K 2006
    38,271
    Re: New To the BBB First Shock process
    Use either shock level. The chart is a little more aggressive but completely safe for the liner.
    Check and adjust the FC as often as possible (no less than an hour) as much as you can until the FC seems to start holding.
    All the tests are fine in the house with the CYA as the exception.
    Likely the cloudiness is just dead algae waiting to be filtered out ... realize sand filters are the slowest at clearing the pool (although the least work)
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    One more thing... well maybe 2 or more.. probably more.. anyway
    Will it take longer if I hold at 20 instead of 35 ?
    as for the sand filter. do you know if you can get DE in less then Giant bags anywhere.. seems to be in 25 lbs everyplace I see
    thanks again..
    Taylor K 2006
    38,271
    20 will probably take slightly longer than 35 ... not sure if the difference would be hours or days though.
    I have heard Walmart sometimes has 10 lb boxes ... be sure to get the stuff for the pool, not food grade.
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    jbizzle.. that is good to know.. I was going to go in there tonight and get some borax just incase I needed it but didnt.. Looks like I will be making a trip tomorrow
    Everyone on this board is Great.. I cant thank you enough..
    Taylor K 2006
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,084
    Keep in mind that adding the DE to the filter will increase the amount of back flushing you will need to do. In your case it will help you out a TON of your CYA level could stand to be cut in 1/2 again to make your life VERY easy, but I understand your concern as it's only going to be open for another month. Try an OCLT tonight as you planned and see what the water looks like tomorrow. My guess say's you'll be somewhat pleased.
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Ok.. It is getting better Yeah!!! I can barley see the bottom of the shallow end
    Last night at 10:15pm
    FC 23
    CC 0
    It is 8am here are my numbers
    FC 20.5
    CC 0
    So should I just monitor every couple of hours today and keep the FC at shock level 20 like pool calculator suggest?
    Or should I bump that FC up alittle higher today ? It is cold, cloudy and windy here right now.
    Taylor K 2006
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    My test at 12 noon today
    FC 16.5
    CC .5
    Must still be something so I used the calculator and bump back up to 26 with a gallon of 12.5
    Now thinking I should have went with TF100 instead of K-2006 I dont wanna run out of FC reagent... Ugh. hopefully I can get thru Monday and get to Leslies since it will be faster than by mail
    Is it normal for the CC to be at 0 then go back up to .5 when you are still shocking?
    Thanks Again.
    Taylor K 2006
    Jul 2011
    Eastern Ohio
    7,084
    Yep....plus keep in mind there is a .5 accuracy of the test too. The 0 could be .5 and the .5 could be 0
    38,271
    no one ever believes us that the TF100 is the better value. Hope you can find the reagents locally. If not, tftestkits.net sells them.
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Live and Learn.. Anyway I went online about an hour ago and ordered some replacement 0870 0871 0013 from tftestkits.
    I have been doing the FC 10ml x .5 with large scoop of 0080. (still have quite a bit left)
    that r-0013 goes quick.. I do have part of my second bottle so I have only done that test a couple times. I ordered the big refill
    I live in OH and they should get her quickly.. I did read a thread about diluting to 5ml adding drops x 2.
    I think I will do that for all except my overnight test.
    I figure that is better than nothing
    Right?
    Thanks once again for the help
    Taylor K 2006
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    ok. I am almost there Pool is sparkling... YEAH.. You all are Great!!!
    8am
    FC 23 (only lost 2 overnight)
    CC 0
    It is super sunny here today so at 1pm I had already went down
    FC 12 (bumped back up to 25)
    CC 0
    Water temp has dropped to 71 beacuse of refill/rain/cold at night
    Is it safe to put the solor cover on with the FC that high ?
    Taylor K 2006
    38,271
    The sun helps break down the CC, so putting the cover on may result in the CC going up and the FC having to break them down. But you can put it on if you like.
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Re: Did my refill today *** Update with Pic****
    You guys are so great... I LOVE the BBB... My pool hasnt been this clear in 2 years!!!
    Thanks to all the wonderful advice on this site.. I went from cloudy water that I couldnt ever see the bottom to what is pictured below in just 3 days.....
    FC 18.5
    CC 0
    PH 7.4
    I passed the OCLT last night and tonight when I got home I have a crystal clear pool!!!!!!!!!!!!!! Very cloudy outside so the picture does not do the water justice
    So now it is safe to let the FC start going down to the 10 range.. Right ??
    Taylor K 2006
  20. Back To Top    #20
    30,414
    ajackson,
    I'm sorry but we don't take well to imposters here on the forum. Put some water in that pool and post a real picture.
    (nice touch painting the steps that light blue where the water line should be but we are not tricked that easily)
    (Yes, let your FC come down to normal range....Nice work! )
