Results 1 to 13 of 13
Thread: Pump timer
    Aug 2010
    Orlando, Florida
    41
    Pump timer
    Let me start by saying that I do not know what kind of timer I have at the moment. I think it's just a generic outdoor timer.
    I'm changing from a single speed 1 HP to a dual speed 1 HP. Is it likely that my current timer will work with the new pump (I mean, are they generally compatible?)? What do I need to know to find out if they are compatible?
    I tried calling some pool stores.. useless. If it wasn't for TFP, I would've filled the pool in with dirt and started a vegetable garden.
    Thanks!
    Sara
    17,000 gal, Posi-Flo Sta-Rite cartridge filter, IG, pebble, Water Ace (GE) 1 HP/1.25 SF 115/230V, 100 GPM (Resid.)/37.5 GPM (public pool), 102 SQ FT filter. Future upgrade: 250 SqFt filter.
    22,543
    Re: Pump timer
    Your timer will work in a sense.
    It will still run your pump on either hi or low but won't automatically switch between them. You'll have to manually switch speeds.
    You'll need an external speed selector switch if the motor didn't come with one already.
    Aug 2010
    Orlando, Florida
    41
    Re: Pump timer
    Thanks! I think I can handle manually switching speeds...
    38,251
    Re: Pump timer
    If you go with the 1HP Superflo 2-speed, mine came with a switch installed on the back of the motor.
    At this point I leave it on low. You could switch it to high for vacuuming or to run a cleaner if needed. Eventually I will remove the switch and put a controller on it to run on high for solar heating.
    Aug 2010
    Orlando, Florida
    41
    Re: Pump timer
    Excellent, Thank you!
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: Pump timer
    This is the timer that will let you set run time on high and rin time on low.
    http://www.amazon.com/Intermatic-PE153- ... pool+timer
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    38,251
    Re: Pump timer
    Or this mechanical one for less $$$:
    http://www.amazon.com/Intermatic-T10604 ... 0039Q7NYI/
    Aug 2010
    Orlando, Florida
    41
    Re: Pump timer
    Thank you! That's super helpful!
    38,251
    Re: Pump timer
    Also realize that any of the automation systems (with or without a SWG) have the ability to control the 2-speed motors ... may not be something you actually need though.
    Aug 2010
    Orlando, Florida
    41
    Re: Pump timer
    Cost is a major concern for me now, so I think that I will just manually switch from high to low as needed. My only concern is that it sounds like some pumps won't start up on low? But even if that's the case, I can still work around it.
    38,251
    Re: Pump timer
    They may not prime on low. But once it is primed, it should have no problem starting back up on low (assuming you have to leaks that allow the pump to loose prime when it is off).
    Aug 2010
    Orlando, Florida
    41
    Re: Pump timer
    You're Awesome.
    38,251
    Re: Pump timer
    Quote Originally Posted by HeritageCove
    You're Awesome.
    Thanks
