Thread: *Edit*Morning update*Crud. I think it got a bit ahead of me.
    Aug 2011
    Virginia Beach
    295
    I'll try to keep it brief & to the point, I think algae may have gotten a start on me. My water had been sparkly for some time, then I noticed it was like Sweet Jane- she lost her sparkle and I knew she wasn't the same. I had to do some Truckin' over the weekend, so I added 182(? large jug) oz of Clorox before I left Friday night and left the sand filter running. When we got home Sunday night it was down to .5 TC so I brought it back up. I've been using the 12% liquid I've found at Ollie's, it seems to still have it's potency. Anyways... the water was still cloudy, but not green. I've vacuumed twice in the last 2 days what seems to be pollen. It's not slimy feeling, not on the walls, and it's not just in the shady spots.
    When we finished swimming a few minutes ago I did a FAS/DPD test and found I now show .5 CC. I've never shown any CC in the past this season. I started to add 90 oz of 12% to bring it up to shock level. I added the first 30 oz, then realized I'd just added acid instead of chlorine. D'OH!
    If I looked at the pool calculator correctly, that will bring my PH down to around 6.9 . I have baking soda/PH increaser to bring that back up once the shock process is finished. I added the 90 oz of chlorine and left the filter running, and also fired up the old Intex cartridge filter (with no element) to help circulate the water better.
    8/6 Mondays numbers were:
    FC: 3.5
    CC: 0
    TC: 3.5
    TA: 110
    CYA: 30
    PH: 8.0 (bought muriatic acid & lowered to 7.5 yesterday)
    These numbers are fairly typical of my weekly testing. I do at least one OTO test daily.
    Like Barney Fife used to say, Let's hope I nipped this in the bud!
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Crud. I think it got a bit ahead of me.
    Sounds like you managed to nip it in the bud - the pool didn't turn green on you.
    [center:3j7zwy9l][youtube:3j7zwy9l]uijLXS-IJZM[/youtube:3j7zwy9l][/center:3j7zwy9l]
    Aug 2011
    Virginia Beach
    295
    I owe it to TFP- Last year I would have been pool stored & had green water. I had to go to my local pool store to get the acid, I didn't trust the "90% better" stuff @ Walmart & Home Depot. They both put up the pool supplies already and now feature school supplies.
    While there I asked about refilling the carboy I have- 2.5 gallons of 12% for $9.00. They have the same Austin's 12% gallons that I've been getting at Ollie's for $2.99. Their price is $4.99. They DID offer to sell me some powder, but when I told the girl that I'd had problems with cyanuric acid creeping up and TA/PH getting out of control when using it she just kind of faded into the displays. Besides- I still have half the small bucket of dichlor I picked up at the start of the season. I used that to get my initial dose of CYA.
    Thanks for the video clip- it was PERFECT! LOL!
    Virginia Beach, VA
    Leisure bay hot tub
    Aug 2011
    Virginia Beach
    295
    Re: *Edit*Morning update*Crud. I think it got a bit ahead of
    At 1:50 this morning FC was 14.5, CC was 0. Later this morning at 7:30 I went out, and the water is visibly clearer. I did another FAS/DPD test (or 4).
    Results:
    14 (might have lost count, no caffeine yet)
    12
    15 (Higher than starting? I don't think so)
    14 again
    I almost started to test PH, but figured it was pointless right now. I just realized I need to test for CC this morning too- make that 5 tests.
    Edit:
    FC 13.5
    CC 0-ish. There was just barely a trace of pink. I'll see how that evolves as the process continues.
    Virginia Beach, VA
    Leisure bay hot tub
    Apr 2012
    SW Ohio
    456
    I think your volume is incorrect I have a 18x52 and mine only holds 6981 gallons, that will throw off your dose amounts like your ma to lower ph etc.....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
