Thread: TA High in Vinyl Liner Pool
    May 2008
    Ohio
    6
    Hi All,
    I’ve been reading this forum, for about 2 yrs now, and I Thank you all, for the Info on how to keep a pool well balanced. This will be my 3rd yr on opening the pool, and it’s time to post a problem I have been dealing with so here it is, ( TA ) first of all, I have well water that has a TA that can ranged from 460 to 540 ppm ( using a Taylor test kit #’s are below, new reagents ) I understand how to lower the TA, I've read all the posts by Chem_Geek and waterbear on the process of doing this, and I have done it many times, so by the time I get it down to about 100 to 120,and I have had it down to 80 a few times. But after doing all this for several days, the aeration, and acid to keep ph 7.1 to 7.2 , I need to add some more water to the pool. And up it goes again. So the bottom line is, I can manage to keep the TA between 150 to 180ppm without much problem. So will these #’s will I be ok with a vinyl liner. I know I have read that it is ok for vinyl liner’s TA to go up to 200ppm but no more than that. And I have been doing my best with your help to keep it below 200. Other then this I have Cristal clear water . Thanks again.
    Tom
    5-8-08
    Temp 67
    TC 3.0
    FC 3.0
    CC .5
    PH: 7.6
    Total Alk 170
    CYA 60
    CA Hardness 62
    Salt 3000
    18x36 Vinyl In ground, Sta-Rite Cristal-Flo T-300bp Sand filter,3/4hp Max-E-Pro Sta-Rite pump,
    Aqua Rite SWG, Automatic Pool Cover, Solar heating.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You have water just like mine. I see the same kind of numbers. The biggest help I've found is a mesh winter cover so I collect rain all winter. I don't have any problem running 180 TA.
    May 2008
    Ohio
    6
    Thanks for the reply JohnT,I'm glad I'm not the only one with this problem,but that is a good idea,so with my autocover, I could start pumping the rain water off the cover through a cartridge fillter back into the pool. I will give that a try.
    Thanks, JohnT
    Tom
