Thread: Calculate Pool Gallons
    I'm not exactly sure how many gallons are in my pool. I keep seeing different amounts from different places. My pool is 27' round 48" deep. I've seen some that say 15,054, 15,500, 16,500, 17,200 etc. I found a calculator that says to multiply 27 x 27 x 4 x 5.9 to get my answer. Can anyone help me out so I know how many gallons of water I'm treating. Thanks a ton.
    Sam
    30k gal IG Pebble Sheen, Jandy Cartridge Filter CV460 150gpm, 650sf Heliocol Solar, Jandy 1.5HP Variable Filter Pump,
    Jandy 1.5HP Spa Booster Pump, Jandy 1.5HP Water Feature Pump (waterfall, wf bypass, deck jets, shelf bubblers)
    38,475
    Re: Calculate Pool Gallons
    Use poolcalculator.com at the bottom.
    Usually the water level is 6" lower than the wall height ... so use 3.5' as the depth (or actually measure it). That gives 15000 gallons.
    Jul 2012
    Lotus, California
    3
    Graphic example... remember to balance units.
    ~ 8,400 gallon, cartridge, IG, fiberglass, 1hp & 120 gpm filter design, ~ 2002
