Results 1 to 7 of 7
Thread: "Chalky" feel on skin when in water - what causes that?
    Jun 2012
    Lafayette, Ca / USA
    260
    I can only best describe the feeling like 'chalky' when I'm in the pool ... I don't smell chlorine when getting out. My FC is bouncing around 5.0-6.0 and my CYA is constant at around 60. I added 182 oz bleach after that test. Is this where the BORATES discussion comes in?
    What causes that chalkiness feel? Another reason we're seriously considering jumping to a SWG system next year.
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,881
    Re: "Chalky" feel on skin when in water - what causes that?
    What are your test results?
    Jun 2012
    Lafayette, Ca / USA
    260
    FC= 5.0
    CC = 0.0
    PH=7.6 (aprox. - from Blue test)
    TA = 110
    CYA = 60 (still - never changes, but I also have not dumped 1/3 of the water)
    CH = 280 (down from 300)
    Temp = 90
    Thanks
    Richard320's Avatar
    Jan 2010
    18,881
    Well, I'm stumped.
    Jun 2012
    Lafayette, Ca / USA
    260
    what might you had suspecting ?? thanks
    Richard320's Avatar
    Jan 2010
    18,881
    Quote Originally Posted by cody21
    I was expecting pH to be way high. And TA, too. Which would leach skin oil out of your skim making it feel dry. Like you'd get on your hands after washing the car or cleaning a sink with ajax.
    May 2014
    Houston
    24
    Did you ever find a solution or answer to this? I have a similar feel, its almost a rough feel even when in the water.
