Thread: My 1st pool store test since conversion from Bacquagoo
    May 2008
    Austin, TX
    27
    I have a simple test kit at home (ordering TF-100 today), my basic numbers are
    Chlorine-5
    pH-7.2
    TA-190
    CYA- 30
    Pool store numbers they have "Pinpoint" Computerized Water Analysis System (not sure if that's good or not)
    FC-2.6
    TC-2.8
    CC-0.2 (because TA is high?)
    pH-7.7
    CYA-43
    TA-158
    They want me to add 3.5qts of muriatic acid to decrease pH. Does this amount sound right?
    I have a 12'x28' AG Doughboy (approx 7900 gal) with a Hayward 1hp pump and sand filter. The water is wonderful
    sparkling blue.
    12' x 28' Doughboy, partially underground, 9100 gal. Hayward pump and sand filter, Barracuda Zippy pressure side cleaner.
    I would not automatically believe their PH test over yours. Since both tests are within the acceptable range I would leave the PH alone.
    30,431
    Just for reinforcement, I am in complete agreement with Jason.
    If you do lower your ph, 3.5 quarts of acid is WAY too much for adjusting a pool your size. I would put about a cup of muriatic acid in and test again. You should find that you will drop the ph to 7.4 or 7.5 with two cups or less.
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    May 2008
    Austin, TX
    27
    That's what I thought, TA didn't seem that high to be adding all that acid.
    Guest
    Re: My 1st pool store test since conversion from Bacquagoo
    Quote Originally Posted by JC45
    Chlorine-5
    pH-7.2
    TA-190
    CYA- 30
    FC-2.6
    TC-2.8
    TA has NOTHING to do with this! It just means that you might need to shock soon
    pH-7.7
    CYA-43
    TA-158
    I am sure that the amount of acid they want you to add is to drop the TA and NOT the pH since adding that amount should drop your TA about 50-60 ppm. This is a more "acceptable" TA (and if you are using liquid chlorine is still too high, IMHO.
    sparkling blue.
    The difference in the ph tests between your home test and the one at the store is very possibly caused by CO2 outgassing from the sample you took to the store, which would cause the pH to rise. (THIS is because of the high TA!)
