Thread: Woops, let my chlorine get too low
    Dec 2011
    Austin, TX
    38
    I got distracted from my new pool and inadvertently let the chlorine get to 1, with 0.5 cc, and pH 7.8. I have been diligent about keeping pH and TC in range since it was installed in the spring. How bad have I fouled up?
    In response I added 374 oz of Chlorine to get to shock level, and about 12 oz of MA liquid (the last of both on hand) and then brushed the pool. I plan to leave the filter on low all through the night. I wont be in a position to tend to it until tomorrow afternoon.
    What do you recommend folks?
    Thanks
    Chris
    Built 2012: 14x28' free formed IG gunite with 4 person spa. 11,000gal, Hayward 2 speed Tristar pump, Hayward 420sq ft cartridge filter , auto tablet chlorinator (I use BBB), 250BTU Hayward heater, quartz pebble finish, LED lighting
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Woops, let my chlorine get too low
    If it was just one day with FC too low, you probably took care of it. And then some.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    boston2austin:
    Yep, I think everything will be OK.
    Sep 2009
    Greentown, IN
    914
    I think you handled it well. We all have an oopsie, got too busy or forgot moment once and awhile. You acted quickly and gave it a good dose of prevention. You might have been ok with less, but you insured yourself with some extra. Nice save
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
