Thread: question about how to add borax in pool
    Jul 2012
    Staten Island, NY
    10
    I've been mixing with it water and slowly pouring it at the return. Can it be put undiluted in the skimmer?
    Morada RTR Supreme AG Pool, Oval 12'x17'x54" 5,400 gallons, Pentair CC75 Cartridge Filter w/1 HP Pump, installed 6/22/12, TF-100, BBB
    38,548
    Re: question about how to add borax in pool
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    4. WITH YOUR PUMP RUNNING add 1/2 the required acid to your pool. You can pour it SLOWLY into the stream of one of your returns or dilute about 1/2 gal at a time in a 5 gal bucket of pool water and broadcast it around the pool. As soon as the acid is in put in 1/2 the borax. Just dump it in the water or pour it in your skimmer.
    5. Brush down the sides of your pool all the way around. This will create currents that mix everything. You are 'stirring' your pool water by doing this. This is a good procedure to follow when you add any chemicals to your water and want to mix them. Anyway, none of us really brush our pools enough, do we?
    EDIT:
    But from Pool School: pool-school/recommended_pool_chemicals
    Borax is available as 20 Mule TeamŽ Borax Natural Laundry Booster. It is sold in the laundry detergent section of most larger grocery stores and some big box stores. Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I add mine slowly undiluted to the skimmer.
