Results 1 to 16 of 16
Thread: need to lower my TA
    need to lower my TA
    I've got some minor issues with algae, took some samples to 3 different pool stores, the first one I'm throwing out cause they say my CYA is 65 The other 2 are pretty close, they are...
    Second store
    FC 4.3
    pH 8.4
    CH 339
    TA 215
    CYA 20
    third store
    FC 4.2
    pH 8.2
    CH 340
    TA 200
    CYA 20
    The pool store is saying to add an entire gallon of muriatic acid to lower the TA. I'm really questioning this. I know I need to get it down and my pH down. The pool Calculator says to add 86 oz of Borax. Looking for some suggestions and conformation.
    Keith
    Intex 15' x 48" AGP (5300 gallons)
    Intex 2,100-Gallon Sand Filter Pump
    Central Mo
    22,553
    Re: need to lower my TA
    If the pool calc is suggesting borax you either put the 'now' in wrong or the 'target' in wrong. Maybe you swapped the target and now values.
    The muriatic acid will lower the pH and also has the effect of lowering the TA, though the pH should be your primary concern. Try to maintain between 7.2 and 7.8. With a TA of 200, it will tend to drift up every couple days so test and redose as needed.
    Use the pool calculator before you just dump a gallon in. You can calculate how much of the muriatic acid to add. When you have that amount, don't add it all at once. Add about 2/3 of the amount and retest the pH after it circulates so you don't take the pH too low. With muriatic acid it's ok to "guesstimate" the amount. It is pretty dangerous stuff to be measuring out so figure out if you need half a gallon or 2/3s and then pour it in front of the return. Retest, repeat
    Vogue Vectra 30' Round (21,200 gallons), Waterway 2HP 2-speed, 27" sand filter - TF100 -- Southern IL - Install 06/2012
    Last minute upgrade from 27' due to error in dealer inventory *yikes*
    38,449
    Also note, that a pH of 8.2 is usually the top of the test, so it could be even higher. That may result in you having to use more MA than the pool calculator initially recommends ... might take a couple iterations.
    Yeah, that's what my problem was, had the pH numbers reversed. From what I understand, if I get the TA in normal range, my pH won't swing so much?
    It's odd with the pH cause when I test it with my drops, I see it being 7.6
    Keith
    Central Mo
    38,449
    What drops? What test kit do you have?
    We generally trust your test way more than pool store testing. How did the pool store do the tests? If they used a strip, I would complete disregard the results.
    Best option is to invest in one of the test kits we recommend and then trust yourself.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Please do not add a full gallon of MA. You need to start with around 30 ounces, let circulate for 30 minutes, and retest.
    I plugged in 3400 gallons, TA of 200, and pH to go from 8.2 to 7.2. I got 30 ounces of MA.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    HTH 3 way tester
    I know, I need to find the extra funds and buy one.
    Keith
    Central Mo
    38,449
    Your pH test may still be better than the pool store if they used strips.
    TA of 200 and pH 8.4 to 7.4 is 23oz MA
    Quote Originally Posted by aa62579
    Keith
    Central Mo
    One did, the other 2 used a tablet.
    Keith
    Central Mo
    38,449
    I think I would trust the drop test over the tablets as well.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Quote Originally Posted by keithk
    Most tests can't accurately measure over 8.2, so that is why I used it. Whether you want to add 23 or 30 ounces, as you can see by both of these numbers, 128 oz would certainly be too much. I would guess that much would take you into the low 6s. Low pH is much worse than a somewhat high TA.
    Add acid each time your pH gets to 7.8 and your TA will come down.
    ~~ Allison ~~
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Upon reading more, if you are confident in your 7.6 result, I would only add 20 ounces.
    ~~ Allison ~~
    I'll check it in the AM and probably take another sample in. Thanks everyone for the suggestions.
    Keith
    Central Mo
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Second store
    FC 4.3
    pH 8.4
    CH 339
    TA 215
    CYA 20
    third store
    FC 4.2
    pH 8.2
    CH 340
    TA 200
    CYA 20
    TA has no effect on algae.
    Are you trying to have perfect test numbers, or a clean, sparkling, sanitary pool?
    Instead of driving from store to store getting inconsistent tests and exposing yourself to the salesmen's charms (cha-ching!), why not just buy your own proper test kit, confirm CYA and drain as needed, then adjust pH, then perform the shock process? The shock process will resolve the algae problem.
    TA can be adjusted at your leisure, when you're bored because the pool is so clear and troublefree.
