Results 1 to 11 of 11
Thread: Will FC levels of 6-8 fade liner? Pool store experience...
    My CYA is at 50 so i try to keep FC around 6-8. I was talking to the pool store guy and he said the only problem i might have with that is possible fading my liner quicker. What are your thoughts.
    I also thought it was interesting when i told him my CYA was high at 50. He said that wasn't high at all and that he wouldn't be concerned until it got to 200?? He has become somewhat of a frriend since he built the pool. I really don't think he is just trying to sell me more chemicals. I think he believes what he tells me. he said i was the first person he has heard of who could maintain my pool using just bleach and muriatic acid. I thought this was interesting. my pool has been crystal clear since i started BBB.
    Jeremiah Hough
    22,000 gallon, vinyl liner, chlorine, with auto cover
    38,371
    Re: Will FC levels of 6-8 fade liner? Pool store experience
    Quote Originally Posted by miahhough
    It will not fade the liner ... he clearly does not understand the CYA/FC relationship (not an uncommon problem) ... or that the active chlorine level in stabilized water is MUCH less than if no stabilizer was present.
    With a CYA of 50ppm, your FC would have to likely be over 30ppm to risk fading the liner due to the chlorine.
    30,426
    Invite your friend to TFP where he may learn several things the Pool Industry does not do a good job with.
    FC of 6-8ppm and CYA of 50 will have no affect on your liner.
    Jul 2012
    Newton NC
    31
    For 12 years I have maintained a CYA of 75-80 and a FC of 6-8. My liner looks great. I have only slight fading on a section of border that is in full sun.
    16k 17X33 IG Vinyl(2000), Pentair Intellifo Variable Speed Pump(2006), Hayward Sand Filter, Aqua Rite SWG w/T9 cell(repl 7/2011), Hayward Natl Gas Heater, TF100 w/magnetic stirrer
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    My CYA is 160 and I have to use so much chlorine my liner is now faded (pool 5 years old) and I am dumping 1/2 my water this weekend to get it back down to a level I can maintain.
    I absolutley thought my pool store people were great to.. Until I learned the real way to take care of a pool from this board.
    14500k inground, vinyl, built in 2007
    Hayward Sand Filter, 1hp Hayward pump, AquaCal electric heat pump
    Taylor K 2006
    copotay's Avatar
    Aug 2011
    Lafayette, La
    146
    Relying to old post, Mine, a new liner as of install last year, 2012, it was a dark blue design, has done a bit of even fading allover within the water level keeping CYA 40 - 50, and Chlorine levels between 6 and 8, Ph 7.6 - 7.8. I get sun in the early day until about 2:00 pm before shade hits it during the summer months about 8 hours of direct sunlight in summer, 5 hours in winter. I do not close my pool during winter because of where I live, and kept a Chlorine level of about 5 because during the winter it would burn off about 2 a day. I make sure to broadcast the bleach evenly over the return jet. I only had to severely shock one time to clear it last summer at about 22 for two days. So I guess along with bleach and sun it faded the liner.
    21 X 52 Sharkline Venture, 10,400 Gallons,
    Hayward Pro Series 18 Sand Filter, BBB Method, Leslies DPD Complete Chlorine Kit, Taylor K-1515-A - Drop Test, FAS-DPD Chlorine
    22,551
    The sun will fade it a lot more than the bleach will. I have a distinctive unfaded pattern right where the steps sit. Since the FC is the same everywhere in the pool it has to be fading from the sun.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I'm currently lowering the CYA level of a new client. Pool is 2 years old. I tested CYA at over 100. Explained relationship. Drained almost half water out and refilled, recirculated 24 hours. Retested CYA next day, using 1:1 dilution method. Result still over 100, meaning his CYA was somewhere around 400. Will be repeating this process. He had a biofilm on much of the liner.
    I've maintained TFP recommended chlorine levels in my pool for 7 years. Any fading of the liner is due to the prior 6 years of pool store chemical procedures like walking around the pool pouring a bucket of 'dissolved' dichlor powder or 'broadcasting' and it settles around the perimeter bleaching out the liner.
    On the section of pool that gets the most sun the worst fading is at the top (above the water line.)
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Keep in mind that all liners fade eventually regardless of chemical levels.
    Very low PH can also lead to accelerated fading.
    copotay's Avatar
    Aug 2011
    Lafayette, La
    146
    I will agree with that because under my ladder step it is not nearly as faded as the rest of the pool below the waterline that gets direct sunlight, I think its just the combination of sun and bleach that helps hasten the fading with the sun really working against it. During the summer sunlight and heat of 98 degrees with indexes over 110, somethings gotta give. Of course as we all know direct sunlight on any object will bleach it out and suck moisture out of anything even UV protected items. I have a deck box by rubbermaid that is supposed to be UV protected but you can tell its getting some oxidation on it, just a matter of time before it turns brittle.
