Thread: High percentage bleach is not stable, can we dilute ?
    Apr 2008
    Indonesia
    311
    Seniors,
    I am using 12% bleach, kept it in the dark. However I am concerned of its shorter shelf life than 6%.
    If I dilute with water for storage, will shelf life be extended or I will have some sort of reaction that maybe hazardeous ?
    Thanks
    SPP
    35,000 GL pool. In Ground. Concrete with all white ceramic tiles. Outdoor but shaded.
    Approx 36 ft by 15 feet. 2HP Hayward Super Pump, Hayward Sand Filter with Zelbrite ( Zeolite ), Hayward Cartridge Filter, Aquamatic Silver+Copper Ionizer ( suspended use since Oct 2008 ), Prozone Ozonator, 2 gram/hr, Analog Flowmeter on pipe
    Back Up Pump & Filter on trolley, Pentair 1.5HP + Pentair Cartridge Filter, Slime Bag 1 micron Jumbo Size, downstream of Cartridge
    It all depends on the purity of the water you use to dillite. Metals will cause problems. Usually dillition is fine, but I wouldn't do it with well water or other questionable water sources.
    Apr 2008
    Indonesia
    311
    thanks Jason. Let me experiment next time in small quantity... :P
    Mar 2007
    San Rafael, CA USA
    12,082
    As long as you prevent the chlorine from getting too warm, then it should still last a reasonable amount of time as shown in the chart at the bottom of this link for high quality chlorinating liquid. I use 12.5% chlorinating liquid from my pool store and get about a month's worth (4 gallons) at a time and I barely notice any difference at all at the end of the month. The average temperature in the hottest part of the summer where I live is around 70F so the half-life is around 315 days so after a month the concentration should drop to around 11.7% so not a big deal.
    Richard
    Apr 2008
    Indonesia
    311
    thanks richard.
