Results 1 to 7 of 7
Thread: Is this a temp sensor?
    Hi!
    This device is strapped into the pipe that outflows from my pool pump and has two purple discs that are crumbling. I will call these resistors until someone corrects me
    I was going to replace it based on the crumbling although the water temp seems to be correct when checked against a thermometer.
    Bob
    Thanks As Always!
    Bob
    23,000 gal in-ground, Aquarite salt sys, Intellitouch i7 +3, Hayward cartridge filter (4) C-5025, Polaris 280 Pool Cleaner, 3/4 HP booster pump, Hydrazzo plaster.
    38,301
    Re: Is this a temp sensor?
    Yes that is a water temp sensor.
    Articfox918's Avatar
    May 2012
    Western, Wisconsin
    99
    Yes I agree with Jbizzle that is a temp sensor..In regards to the purple discs that are crumbling those look like UY connectors to me for connecting wires together.
    POOL SIZE: 27 FT round 52" Deep on edges 66" Deep in center
    FILTER TYPE: Hayward Sand Filter
    PUMP SIZE: Hayward 1 HP Pump 60GPM
    FILTER SIZE/FLOW RATE: Unknown
    HEATER: None at the moment but in process of making my solar panels should be operational by next season!
    OK - so I'll replace those by the wet season then.
    Thanks
    Thanks As Always!
    Bob
    38,301
    Yup, sorry I overlooked the wire crimps that are crumbling ... easy enough to cut off and replace
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by aquaman
    Thanks
    They were probably put in when the original temp sensor failed, and for, whatever reason, the repairman didn't want to run a new wire. If the sensor needs to be replaced again, buy one with a long enough wire to get to wherever it has to go (as the splice connectors age, they add resistance, which affects the accuracy of the sensor).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Fantastic!
    It had been replaced at one time (this tells the solar to come on as well correct?)
    That was a sweet piece of information!
    Thanks!
    All u guyz!
    Thanks As Always!
    Bob
