Thread: Solar cover has some algae on it, ok to put on pool?
    Jun 2012
    Louisville, KY
    266
    With temps in the 60s at night I need to start using my solar cover. It has small spots of viable green algae. Is it OK to put on the pool? If not can I just spray it down or do I need to hit it up with a bleach/water mix?
    CYA=45, FC is maintained between 6 and 8, CC=0
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: Solar cover has some algae on it, ok to put on pool?
    I think you're asking for trouble. Get what you can off before you put it in. Then I'd run FC up to shock level before I put the cover on, and then I'd make sure every inch of the cover got wet.
    Jun 2012
    Louisville, KY
    266
    Quote Originally Posted by Richard320
    That's sorta what I was thinking. Thanks.
    Are there any tips on keeping algae off or am I going to deal with this no matter what. Algae on the cover when stored or rolled that is.
    I haven't noticed any on my cover. I keep it rolled up and wrapped in a tarp (hanging from the fence - similar to how the saddles work, except I used rope and bungee cords). Maybe I'm just lucky.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
