Thread: Deck Box Coushions
    Deck Box Coushions
    So I've got one of these:
    http://www.amazon.com/Suncast-DB9750-Ex ... m_ol_img_3
    and I'm thinking of picking up 2 more for various places in the yard... BUT.... I'd like to dress them up with some coushions. Then I see a 4' coushion is like $40 cheapest on Amazon.com (http://www.amazon.com/4-Foot-Bench-Cush ... 15&sr=1-10 for example). That's a little redonk IMO.
    I've got a sewing machine I (sorta) know how to use - So for you crafty peeps out there - how do you make outdoor coushions? Like is there special fabric and/or filler meant for outdoor use?
    Also - how would I attach it? There's really nothing to tie it to on that box.
    21' Round (12k Gallons) AG
    Strong Pools Colosseum Riser 56", 1 hp Sand filter, 10'x12' Composite Deck,
    Auquacal Aerotemp Heat Pump, Also: Sundance Cameo Spa
    See my pool build thread here: Katkami's Pool Build - With time lapse video!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    There's no reason you can't make them yourself, but to keep them from fading you'll need to use outdoor fabric like Sunbrella. Once you price it, you'll see why it's expensive.
    I'm getting estimates for cushions for a built in bench we did. The first one I thought was high at $800, then I went to Calico Corners and it doubled This is for $28 yd. Sunbrella. Nothin fancy. I wish I knew how to sew! I'm going to an upholstering co. tomorrow and praying the price goes waaaay down. It's just 2 cushions, one is 8' and the other just over 5'.
    No Cover Charge
    17,000 gal IG w/ raised 8' spillover spa, 3M plaster, 10' stainless rain WF, Pentair SAM lights, Sta-Rite Sys3 cart. filter, Intellichlor SWG, 400kBTU Gas Heater, Paramount IF Cleaners, ET-8 Wireless Remote
    Apr 2008
    Central Texas
    326
    One low budget solution may be to just buy a pad for an outdoor lounge chair and cut off the part that goes on the upright part of the chair. The lower section might be just the right length for the deck box lid.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Re: Deck Box Coushions
    Quote Originally Posted by katkami
    put Velcro tape on the top of the box and the bottom of the cushion.
    IG Liner
    SWG
    15000 Gallons
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    I'm pretty crafty and have made many a cushion for seats. You will need an outdoor fabric of sorts to use if you sew it yourself. Otherwise it will bleed and fade and you will have wasted your $ Two best ways to do it.
    1) Find an already made outdoor cushion from Home Depot or Lowes Etc. Cut it to size and resew the end to make it fit. Using a smaller thickness cushion will be easier.
    2) Buy your own fabric and water resistant pad and DIY. Online there are alot of places you can get this fabric but it is usually $20-30 a yard. For a 4ft cushion you are looking at 2.7 yards to make it so the 40$ premade one is not really a bad price. If you diy then velcro is the best choice to affix it but you need an all plastic based velcro cuz a fabric one will get wet and not stick anymore after a few rains. You will have to sew the velcro on, possibly by hand unless the pad is removable with a zipper. Hope this helps!
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
