Thread: SWG percent and run time
    I am crazy happy with the results of my pool this year so far:
    Temp 86
    Salt 3800
    FC 5+( my taylor 2006 tops out at 5)
    PH 7.5
    TA 80
    CH 70
    CYA 50
    Borates 50
    So far after adding Borates, 1 month ago, all I adjust is Ph every now an then to lower 0.2 points. My question though is my FC: I run my pump 12 hours (2Am-2PM) and my Hayward GoldlineSWG with T-3 cell is set at 35% output. Should I be concerned that my FC levels are ALWAYS 5+? As water temp cools I turn down the SWG %...but how low can you go?
    I have a taylor 2006 and another quick PH FC that I used and both return the same value. Does the T100 kit allow reading over 5?
    Any help is appreciated
    Robert
    28000 gallon
    1-1/2 hp pump
    244 hayward sand filter
    Hayward SWG
    BBB method rules!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: SWG percent and run time
    The Taylor K-2006 has the FAS-DPD test (powder) and you count the drops and can go higher than 5. Are you sure it's not the K-2005? In cooler weather you can actually turn your pump run time down also.
    It very well may be a 2005 as I do not have any powder. It actually is sold by Leslie pools but is Taylor materials throughout: I think I need a TF100!
    Robert
    28000 gallon
    1-1/2 hp pump
    Hayward SWG
    BBB method rules!
    38,293
    You can just add the FAS-DPD chlorine test to your kit and give the equivalent of the K2006. You can order it from tftestkits.net
    Or just get a whole new kit if you are running low on reagents.
    Posted from my Droid with Tapatalk ... sorry if my response is short
