Results 1 to 15 of 15
Thread: I have added Borates, but see particles in water.
    May 2012
    Allentown, PA
    219
    FC 3.0
    PH 7.6
    CH 160
    Alk 100
    CYA 40
    Borates 40ish
    So underwater with goggles I see small particles, at first I thought they were tiny bubbles. In the sunlight you can see really tiny white particles. Is this the borates? The water looks very clean from the sidewalk, but not as clear as it did prior to the borates. I am not upset by these particles, but just confused as to what they are and if anyone else knows what I'm talking about. Thanks everyone!
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Jul 2009
    Olney, MD
    218
    Re: I have added Borates, but see particles in water.
    Did you just recently add the borates? If so, what method did you use?
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    May 2012
    Allentown, PA
    219
    I added them 10 days ago just poured them in front of the returns. I put 2 boxes into the skimmer and backwashed the sand filter today, pressure was not built up though.
    Jul 2009
    Olney, MD
    218
    I can think of two possibilities...
    1. at some point your pH was way high (probably during the borax addition) and some calcium has precipitated out, in which case, give it some time, and maybe lower down to 7.2 for a while to see if that will improve it
    2. one of the benefits of borates is improved water clarity, if it bothers you, maybe try adding some DE to your sand filter to get better filtration of small particles
    May 2012
    Allentown, PA
    219
    I know I added borax first then the muriatic acid. I realized that I put it in in the wrong order right after I added it to the pool. It took me about 15 minutes to add all the chemicals for each of the 2 doses. If it is calcium what is the best way to get it out? Will it dissolve over time?
    Jul 2009
    Olney, MD
    218
    Because you are seeing particles and the water isn't really cloudy, if it was me, I would do both. Lower the pH to 7.2 and add some DE to the filter.
    BTW, if your CH isn't from your fill water, then stop adding it to the pool. You don't need it with a vinyl liner pool.
    May 2012
    Allentown, PA
    219
    My CH is from fill water. I will lower ph and add DE. Thanks for the help I will give you an update in a few days.
    May 2012
    Allentown, PA
    219
    I'm sure it is on here somewhere, but how do I add DE to my sand filter? Also how much DE do I add? Thanks again for your help.
    38,524
    Quote Originally Posted by doublewide6
    Pool School:
    pool-school/add_de_to_a_sand_filter
    May 2012
    Allentown, PA
    219
    I noticed that the returns were blowing out air bubbles. I looked at my Liquidator and noticed that after the flowmeter there were bubbles in the line. I took the flow meter out of the loop and bypassed it. The flow meter was cracked on the bottom letting in air. I called HASA and they are sending out a new one for free (good company). I added the DE before I made this discovery. I think the the tiny white particles are air bubbles and now I know how they got in the water. I figured out my problem after the pump ran for the day adding more bubbles. There are still bubbles in the water, I'm thinking that by the end of the day tomorrow they should be gone or noticeably less. Why don't these bubbles just float up and dissolve? Have you ever heard of something like this? Also the water looks really clear from the pool deck. It's just underwater that you can see these bubbles. Also once the DE is added does the filter pressure always stay 1 degree higher or will it go back when backwashed. And, is it good to have a little DE in a sand filter just to filter better, I never used any DE, but I might continue to since I have 20lbs. Thanks for all the help.
    38,524
    Adding DE in the sand is not required, but it can help the pool clear more quickly.
    May 2012
    Allentown, PA
    219
    Once the DE is added does the filter pressure always stay 1 degree higher or will it go back when backwashed. And, is it good to have a little DE in a sand filter just to filter better, I never used any DE, but I might continue to since I have 20lbs. I noticed some of the DE came back in the pool and settled on the bottom in a few spots.
    38,524
    backwashing will remove the DE you add do the pressure should go back to normal. Using it is optional. But since you have it, use it if the water is not crystal clear.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    May 2012
    Allentown, PA
    219
    Thanks Blizzle, your the Shizzle.
    38,524
    You are likely one of the few that know how my name originated
