Thread: Adding 12.5%
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Adding 12.5%
    Hello again, I am very new to this method and today was the first day I was not here in the am to check chlorine level
    my K 2006 is not here yet so I did a OTO a few mins ago and it said 0 nada nothing. No yellow at all.
    The pool calculator said add 101 oz to bump fc up to 7 so that is what I put in.
    I leave for work by 6am and it is very dark and very scary out by the pool that early. I have a hard time reading color scale in the house.
    I am considering a SWG for next season to help with my work hours and the fear factor
    Do you think the 7 will be sufficient until tomorrow evening ?
    Or should I bump up the level more?
    I am not sure yet what my cya is because last time pool store checked (more than a week ago) I was at 35
    however before switching I was going thru 4 pucks in my auto chlorinator every 2 or 3 days.. (50 lbs in June) Several others on board thought
    CYA was probably Much higher.. My K-2006 should be here this week.
    Any answers would be greatly appreciated.
    Thank you
    14500k inground, vinyl, built in 2007
    Hayward Sand Filter, 1hp Hayward pump, AquaCal electric heat pump
    Taylor K 2006
    38,371
    Re: Adding 12.5%
    Hard to say is 7ppm is enough or not without knowing the CYA and without knowing if something is growing in the water consuming your FC.
    A "normal" pool once clear and balanced uses 2-4ppm of FC per day.
    The FAS-DPD test in the K-2006 is much more accurate than the OTO test. Once you get the kit, post a full set of results. Until then, just keep adding the FC to keep your OTO test pretty yellow by the time you check it again.
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Re: Adding 12.5%
    Ok.. that is what I will do
    Thanks for the speedy reply
    Taylor K 2006
