Results 1 to 8 of 8
Thread: Don't think this is algae
    May 2012
    Clarksville, Tn
    22
    Pool has been off for three days due to a power outage and I went out and looked at the pool today and it still looks good but on the top of the water were several groups of egg type clusters floating around. Does anyone know what they are and is it safe to turn pool back on?
    I have a Hayward vari-flo xl-valve. Hp 1.5 Model SM-1700t. Sand filter.
    I believe I have a 24" above ground round pool. Liner has fish on top and a ocean scene on bottom.
    We live in clarksville, Tn. The pool is in full sun.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Don't think this is algae
    You mean egg-shaped? Looks like a poached egg? Looks like birds nest soup?
    At this point it could be anything from pollen to white mold. How 'bout a picture?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    My first instinct is that you have frog eggs in the pool. Skim and save or skim and toss...
    May 2012
    Clarksville, Tn
    22
    i think that it is frog larve theres are two frogs huddled over by the skimmer....
    clear sacs with black things in them. can i start the filter or do i need to try to net these out.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by sasanewpool
    I'd net them - they float and will likely just float in the skimmer until you go to get them out.
    May 2012
    Clarksville, Tn
    22
    thanks
    May 2012
    Clarksville, Tn
    22
    after getting what i thought was most of the eggs out today i see a few tadpoles moving around do i do a shock process to kill them? or is there another way?
    Jun 2012
    Mint Hill, NC
    2,589
    Current test results?
    My neighbor's frogs are chlorine adapted to a degree but they stop laying eggs as his chlorine goes up. I think this is fairly self limiting.
