Thread: retaining wall
    Jul 2012
    Mississippi Gulf Coast
    9
    retaining wall
    When installing a vinyl or fiberglass pool partially above ground, would the retaining wall go up before or after the pool set? Thanks
    3736 gal, AG-Intex 15'x48", SWS pump Krystal Clear-CS8110, KC-637R Filter Pump, TF 100 Test Kit, Shreveport LA., Jul 2012
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: retaining wall
    Welcome to TFP!
    It's probably going to depend on how far from the pool it is. It would be hard to build if you couldn't work between the pool and the wall after the pool goes up. Soil conditions may make it necessary to do it quickly in some cases.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: retaining wall
    I worked on mine the entire time they were building my pool, but my wall began at about 6' from the pool.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
