Thread: Plastic or stainless light niche?
    My PB prefers plastic... I had asked for stainless. Is there any issue over time with salt water or chlorine and a stainless steel niche? Seems to me that the only drawback to plastic is initially at the time it is shot if it cracks... any other reason to go with stainless?
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Plastic or stainless light niche?
    Stainless is a misnomer. It will corrode and rust, just not as fast as normal steel. Go ask anyone with a sailboat.
    I'd use plastic.
    22,543
    I vote for plastic as well. The problem with stainless is that they're most likely going to be 302 and will corrode over time as Richard said.
    Stainless works great if it is in air, there is an issue called crevice corrosion that can affect stainless that is not exposed to air (such as when its underwater). That is why boats that have stainless fittings up top will use bronze or plastic fittings underwater.
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    Do the Pentair stainless steel niches have some special coating that will inhibit corrosion? They sell them as the Cadillac niche for their lights. They recommended them over the plastic, although they said they sell a lot of plastic as well. My PB already ordered them... I thought I could still change this morning... guess not.
