Thread: Pool Will Be Unattended for 19 Days
    Aug 2009
    Bloomington, IL
    11
    My pool will be unattended for 19 days in September. I live in Central Illinois.
    What should I do with the pool while Im gone?
    1. Should I bring it up to shock level the day before I leave and let the circulation system run as usual? It is on a timer. It would run about 7 hours per day. I have an opaque, automatic cover. So I would probably lose at most 1 ppm of chlorine per day.
    2. Should I bring it up to shock level the day before I leave, then shut off the circulation system and let it sit for 19 days? If so, should I drain and clean my DE filter after I shut the circulation system off? Again, the opaque, automatic cover would ensure that I lose at most 1 ppm per day.
    3. Other suggestions?
    After I return I would get everything up to snuff and then close the pool down for the season.
    IG
    27,000 gallons
    DE filter
    BBB Method
    Taylor K-2006C Test Kit
    Opaque automatic cover.
    Pool usually covered unless there are swimmers.
    22,553
    Re: Pool Will Be Unattended for 19 Days
    I'd raise it to shock level and cover it. Let the pump run normally.
    It would be nice if you could have a friend or neighbor go buy once a week and check things and add a little FC.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Do you have a puck feeder? You could do both - raise it to shock and set the puck feeder on a very low flow to add just a touch of FC each day. Your CYA levels will rise but you can deal with that when you are back.
