Thread: Silica Sand #20: Lowes vs. Pool Stores
    Next weekend I will install a Pentair Tagelus TA 100D sand filter. It requires 600 pounds of media. I plan to use a pea gravel base of 150 pounds and top that with 450 pounds of silica. Pool stores (Leslies and mom/pops) around town want $10-$12 for a 50 pound bag. Lowes charges $9 for a 100 pound bags if silica 20; they stock it in the masonry aisle. The bag mentioned a several uses for silica sand but did not list swimming pool filters.
    Q1: are all silica 20s the same?
    Q2: what is the best way to extract sand from the old filter? I'm thinking of a coffee can attached to a pole and scoop it out slowly.
    24000 gallon in-ground | 500 gallon spill-over spa | SWCG T-15 cell | PS-8 control panel | Solar panel heating | Propane heater | Jacuzzi TM 31 sand filter | Jacuzzi 2HP 240V pumps (one each for filter and spa jets) | Jacuzzi TM 31 sand filter | Auto-leveler |
    Re: Silica Sand #20: Lowes vs. Pool Stores
    We tried several Lowes here in North Florida without any luck... they had the sand you mentioned in the Masonry aisle - but we were afraid to try it. We finally found silica 20 at Home Depot for around $5 per 50lb bag... and it is specifically for pools (plainly marked on the bags - Pool Sand).
    You might try there.
    _________________
    Don
    18' x 48" Intex Ultra Frame
    Intex 2650 Sand Filter and Pump
    BBB Method
    Feb 2008
    Denton, TX
    5,061
    Unless the bag says that the sand can be used for pools, I would avoid it. Pool sand is subject to quality controls that masonry sand and others are not subject to.
    Apr 2012
    Bonner Springs, Kansas
    109
    To get the sand out, I've used a 5 gallon shop vac (the big ones with the 2" hose). You need to empty it often as it makes hit hard to carry with all the wet sand, but that let's you suck out the sand and just dump it. When you're done, just make sure you clean the vac well.
    16'x32' -> 3' shallow, 8' deep ~22,000 gallon igp - Vinyl Liner.
    Sand Filter: Jacuzzi 225l-7 Sand Filter - 250lbs
    Pump: Hayward Max-Flo XL 1hp
    SWG: CircuPool RJ+ 60
    Water Source: Home Tap water (TA:230, CH:220)
