Results 1 to 16 of 16
Thread: Use for Pucks?
    Use for Pucks?
    I have a bunch of pucks I will not be using now. Clorox makes a toilet bowl cleaner that is dichlor that goes in the toilet tank. Seems like my unused pucks could be used the same way. Thoughts?
    Doughboy Desert Spring 24 round
    1 1/2 HP Pump
    16,000 Gallons
    Sand Filter
    38,284
    Re: Use for Pucks?
    I think any of the products that are put in the toilet bowl are pretty harsh on the rubber and plastic in the tank ... personally, I would not use them.
    Save the tablets for vacations or for future years where you may need to bump the CYA.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Use for Pucks?
    You can use them in the toilet, but you will not like how strong the smell is, unless you are flushing a lot. The concentration is also pretty distructive to plastic and rubber in the tank itself.
    As stated above, they are an OK solution for vacation use, so long as you leave a little CYA headroom for their use.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Feb 2008
    Denton, TX
    5,061
    Re: Use for Pucks?
    Tablets are strongly acidic and will create a very acidic environment in that tank that could cause damage to metal and plastic surfaces in there. And like elwood58 says, the chlorine smell would be fairly stout. Best thing to do would be for you to hang onto them for future use (vacations, times when your CYA is a little low, etc.).
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Use for Pucks?
    Pucks will keep for years as long as they are kept dry. My CYA needed a little bump due to lots of rain this summer so I have been using pucks that have been stored in my garage for 4 years.
    Love TFP? Become a
    TFP Supporter!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Use for Pucks?
    Water Skeet?
    :P
    Jun 2012
    Blaine, MN
    106
    Re: Use for Pucks?
    We just put in a new toilet for my dad and they said to stay away from in-bowl cleaners. They are too harsh and can ruin the porcelian (sp?) finish.
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    Jul 2012
    San Mateo, California
    14
    Re: Use for Pucks?
    How much CYA can you expect from a puck? or FC, for that matter.
    Is there a table somewhere in the forum?
    Thanks!
    2,600 gallon outdoor pool/spa, rectangular 15' x 8' x 3.5'Deep, IG plaster (age 25+years)
    Yosemite Hetch Hetchy tap water, nice and soft.
    DE 60sqft 120 gpm Hayward, Filter Pump 2.0 hp with 10.5 SF, Jet Pump 2.0 hp with 1.0 SF, Rheem 400K BTU/hr
    BBB starting Aug 2012.
    22,549
    Re: Use for Pucks?
    You can use the "Effects of Adding Chemicals" section at the bottom of the Pool Calc to figure how much a tablet would add. Just put your pool size in the cell at the top and then use the weight of the tablet to see what one would add.
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Use for Pucks?
    You'll need to know the weight of each puck. Typically they are ~7-8 oz each.
    Jul 2012
    14
    Re: Use for Pucks?
    Baba Rambler and UnderWaterVaya,
    I found the Pool Calculator, thanks!
    But the Effects of Adding Chemicals have a choice for Trichlor. Is that the same as almost the same as pucks, assuming most of the weight of the pucks is Trichlor and not the other constituents, like CYA (cyanuric acid)?
    It must be, b/c the calculator gives you the 4 different effects (chlorine, CYA, pH, Salt) from the "Trichlor" choice.
    38,284
    Re: Use for Pucks?
    pucks = trichlor
    The CYA is actually part of the tri-chlor molecule.
    Jul 2012
    14
    Re: Use for Pucks?
    perfect
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Use for Pucks?
    Just to expand a little...
    Pucks can come in two forms:
    Trichlor & CalHypo. CalHypo pucks are typically wrong for pools for various reasons and are intended for ponds as I understand it.
    Trichlor can be supplied as a puck or a powder. Either way the weight tells you the impact this will have on the pool.
    Trichlor from some companies also comes with added ingredients sometimes - check the label. Some include copper...
    38,284
    Re: Use for Pucks?
    Well, let me qualify that. There are some pucks that are not tri-chlor ... there are some that are cal-hypo (I think) and some I heard about that actually have no chlorine in them (just baking soda and some other stuff).
    Looks like UWV also caught my omission.
    Jul 2012
    14
    Re: Use for Pucks?
    Thanks for all the help.
    My 1" puck is a TriChlor puck. 1" is about 0.5 oz.
    The pool calc is great.
