Thread: Algae growth
    Algae growth
    we have had a ton of rain here in East Tennessee. I have been keeping levels around 3 with liquid store bleach, however today I noticed some algae growth behind our wedding cake stairs and around corners of the wall, Not really green algae but more yellow green. Just on floor/wall crease on one side and then around stairs....I have 0 cc, and 3 Fc, so not sure what to do. I just vacuumed it really good and cleaned all the spots that I saw. Is this a huge concern? Never had algae in the past, but we haven't had 4 inches of rain each week in the past either?
    21 ft Round Dough Boy
    3/4 horsepower Dough Boy PowerPak II pump
    Vinyl Liner
    baqua goo convert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Algae growth
    What is your cya level?
    Since you have algae, you need to do the shocking process.
    Re: Algae growth
    Cya is around 30, PH is 7.8, I just added bleach to 12 per the calculator, so hoping that works. What do you think?
    Vinyl Liner
    baqua goo convert
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Algae growth
    With a cya of 30 ppm, you should never let your FC drop below 2 ppm ...2-6 ppm is the normal range according to poolcalculator.com.
    To raise your 9100 gallon pool (I assumed 3.5 ft water depth) to your shock level for 30 ppm cya of 13 ppm FC (from 3 ppm FC), poolcalculator.com gives me 189 ounces of 6% bleach (about 1.5 gallons).
    12 ounces will only raise it ~0.6 ppm FC.
