Results 1 to 19 of 19
Thread: Help new fill with new liner
    Still cloudy because of dirt from the water fill. New liner installed. Pump up and running here are my numbers
    FC 0
    PH 0
    TA 120
    CH 80
    CYA 0
    Where do I start and how do I raise the PH? Thanks
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: Help new fill with new liner
    what did u use to get those numbers? a PH of zero.. would burn your skin instantly..... plus all other metals it came into contact with....
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Repost you ph number, you posted 0.
    You should start getting some chlorine in the pool per poolcalculator.com. Next, you should start getting some cya in the water. See: http://www.troublefreepool.com/pool-...mmended_levels
    Was very little color slight pink tinge with the ph
    Central, VA
    sorry did Ph test again light but think 7.2 sorry
    Central, VA
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by koliver13
    7.2 is okay for now. If you are having trouble reading it, you can add another drop of reagent...doing that just makes the color "deeper" and is sometimes easier to read.
    thanks so I added 1 gallon of 12% bleach. Hung my with granular stabilizer in front of the return. Any thing else i should do now retest in several hours?
    Central, VA
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How much cya is in your sock and what is your target? Don't test for it for a few days, it can take a week to show up in test.
    About 2lbs in sock full sun so I would like my CYA about what 40 or 50?
    Central, VA
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    50 ppm cya for full sun, but be careful, cya is easy add, but drain/refill to remove.
    Ill check the cya is a couple days and see where it is before I add any more stabilizer. Thanks
    Central, VA
    No way should I be second guessing the pros, so take what I say with a giant grain of salt: but, 50 seems high to me. I'd target 40 and use it like that for a bit to be sure you want it higher. Easy to add, hard to subtract. You want it as low as is easy to maintain daily, especially if you travel much and want some leeway to use pucks very infrequently for vacations.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Apr 2012
    SW Ohio
    456
    according to the pool calculator assuming the pool is 23000 gallons and he has no cya at all it would take 123 oz by weight of stabilizer to achieve 40 ppm and according to the pool calc 32 oz would only raise the cya to 10 ppm.......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Thanks for all the input. I will measure tonight to see If I have any CYA but I also thought i would need to add more stabilizer to reach 40-50. the water is clear but still dirty. Measured FC last night at 4.5 with .5 CC. This morning was cloudy so remeasured got reading of 3.0 and .5. should I continue to moniter before adding any more bleach and finding out what my CYA is?
    Central, VA
    New liner and fill Questions
    Added 4 lbs of stabilizer. Been adding Bleach. Will test CYA tonight started with 0
    FC 4-5
    CC .5
    PH 7.5
    TA 120
    CH 80
    CYA?
    Question is do I need to shock when I've reached my CYA? Do I do an overnight FC test at that time? I keep adding bleach to keep the number up until I have a CYA read is that correct? Have full sun would like to keep at 40. Going slow on the CYA add to make sure I don't over do. I'm still cleaning out the dirt from the fill but it looks clear but still have dirt in robot and skimmer stockings. I should have it cleared out by tomorrow. Thanks
    Central, VA
    Jul 2009
    Olney, MD
    218
    Re: New liner and fill Questions
    According to the poolcalculator 4 lbs. should give you a CYA level of 21. The CYA might take up to a week to show on your testing. You can assume that is what you have in your pool and adjust your chlorine level accordingly. If you have dirt in your fill water, then yes, you should be shocking and doing the overnight test. Your shock level should be 12 (based on a CYA of 21) from the poolcalculator. If you successfully shock now, you won't need to re-shock if you add more CYA next week, just adjust your daily chlorine level based on your new CYA level.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    I know I have 4lbs of stabilizer left I will add 2lbs and test. Will shock tonight and continue to moniter. Thanks for the help
    Central, VA
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    cya takes up to a week to show up. Since you know you have added 4 lbs... add the 2 lbs more you mentioned...that should take you to ~31 ppm. Wait a few days to test for it, but assume the cya is in there for FC levels.
    Since your water is clear, but you have had dirt, I would do a Overnight Chlorine Loss Test (OCLT), I would run your FC up to 12 ppm (your current shocking level) to do the test.
    Ok I understand and will follow your directions. thanks again.
    Central, VA
