Results 1 to 10 of 10
Thread: Return Leak
    Return Leak
    I have an in-ground fiberglass pool with a leak in the return line of the skimmer. Is there any way of repairing this without tearing up the concrete deck? Do they make some kind of insert that would go in the return line to repair it?
    Thanks
    14500k inground, vinyl, built in 2007
    Hayward Sand Filter, 1hp Hayward pump, AquaCal electric heat pump
    Taylor K 2006
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Return Leak
    Welcome to tfp, toolman
    Sounds like you leak is on the suction side (since you refer to the skimmer) and not the return side. Are you getting air in you pump leaf basket?
    Re: Return Leak
    It is in the return line from the skimmer. There is no air getting in the pump and I'm still able to vacuum the pool OK but if I run the pump with that line open the earth under the concrete deck begins to cave in. What I've been doing is just running the pump with out the skimmer return and only using the skimmer return to vacuum.
    Thanks
    Taylor K 2006
    Re: Return Leak
    Yes it is the suction side not the return.
    Thanks
    Taylor K 2006
    22,553
    Re: Return Leak
    Normally a suction side leak won't leak water out when it's running especially when a vacuum is hooked to it. And they almost always create air in the pump basket.
    Can you take a pic of the issue you're having.
    How are you shutting off the flow from the skimmer?
    Re: Return Leak
    I can turn off the skimmer by turning the ball valve and just using the 2 other suction spots in the bottom of the pool.
    Taylor K 2006
    22,553
    Re: Return Leak
    But there will still be water in the lines even when you turn it off. Are you losing water in the pool? If you have an autofill it may be masking it.
    Re: Return Leak
    Yes I am losing water, this is one of the reasons I'm trying to find out if anyone has ever heard of someone making an insert to go into the vacuum line, or do I just need to bust out all the concrete to fix this.
    Taylor K 2006
    22,553
    Re: Return Leak
    They make inserts for pressure lines and even they don't work very well, but no insert for a suction line.
    You may be able to tunnel to the leak if it's not too far under the deck.
    Re: Return Leak
    Ok thanks for all your help
    Taylor K 2006
