Thread: Des Moines, Iowa pool lover
    Hello from Des Moines, Iowa. Just purchased last month a 15' X 42" metal frame pool by Summer Escapes. Rushed to put it up in the heat on what was thought to be level ground. WRONG. It became unlevel to the point of damaging the integrity of the pool frame, so was taken down and stored. Next spring we will be hiring an excavator to come in and level off the back half of the back yard. Our plan is to turn that half of the yard into an oasis of sorts.
    Had an Intex pool several years ago with the inflatable ring and done the same thing...it was beautiful. I have never had problems with cloudy, green, etc. water. Chemical levels checked daily and adjustments made if necessary. Love it!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Des Moines, Iowa pool lover
    Welcome to tfp, PAEarp
    Go Cyclones! (unless you are a hawkeye fan )
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You're done SLAMing when:
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    Welcome!
    Go Hawkeyes! (Unless you're a Cyclones fan )
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    Sorry guys, I am an Iowa Hawkeye fan and that is only because I am the only female in my home other than the dogs, and the men are Hawkeye fans. Personally, I hate football. LOL
    Thanks for the welcome
    Patti Earp
