Thread: Proper mixture of muriatic acid to clean DE filter
    Taylorsville, MD
    35
    I have a Hayward Perflex EC65 - I've always done the soak with dishwasher detergent, but never have done an acid bath...
    My question is how to get the proper mix ratio muriatic acid/water.
    the EC65 manual states 1:1 ratio of 20% acid....
    my acid is 30% and the bucket filled with water is pretty close to the full 5 gallons - so how much acid should i add?
    and how long should i let them soak? (I currently have them soaking in TSP, gonna do that for 4 hours)
    Using BBB successfully for over 5 years!
    16x32 vinyl grecian, Hayward EC65, 1hp super pump, Clear solar cover, Loop-lok winter cover, "The Pool Cleaner" 2 wheel suction cleaner
    Jul 2009
    Olney, MD
    218
    Re: Proper mixture of muriatic acid to clean DE filter
    Here is a great soure of info on acid cleaning the DE fiters...
    http://www.troublefreepool.com/use-a...ers-t4086.html
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
