Thread: Will soot and ash have an affect on water chemistry?
    Jul 2012
    Tulsa, OK
    24
    We've got an uncontrolled widlfire burning southwest of here that has already claimed over 50,000 acres. It's about 30 miles away, but my pool has gathered a significant amount of soot and ashes today.
    Will this have any affect on the water balance? I tested this evening and noticed that the CC was 0.5 but that was the only apparent change.
    Do I need to do anything other that give it a good vacuum tomorrow?
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Will soot and ash have an affect on water chemistry?
    I didn't notice any big difference in the chemistry when we had a big fire down here. Lots of ash on the surface is all.
    Jun 2010
    Glendale, CA
    513
    I'm right in the foothills where the Station fire started. Our entire property was covered in a thick layer of ash - you could make footprints in the "snow" - which continued to rain down until the rains came in the winter. I never noticed anything strange in the chemistry - though the load on the filter was significant.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I'd keep an eye on pH just in case. Isn't ash acidic?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2010
    Philly
    332
    Quote Originally Posted by frogabog
    Ash is alkaline. I believe a significant portion of wood ash is calcium carbonate? Or maybe it's potassium carbonate. I do know that wood ash is a good soil amendment for acidic soils.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Richard320's Avatar
    Jan 2010
    18,967
    No, it should be basic. Pioneers used to leach wood ashes to make lye which they used to make soap.
