Thread: Borax and SWG
    Borax and SWG
    I am using the Liquidator this year, but considering going back to SWG for next season. My question pertains to Borax. As LQ users know, the tank tends to collect precipitate flakes of whitish "salts." This year I decided to add 50 ppm borates to my pool in the form of Borax, buffered with muriatic acid. Interestingly, when I did that, all that precipitate in my LQ vanished. And I haven't had to clean any buildup off the OUT float because there isn't any! I used to use Intex SWG for several years and usually had to replace the cell every year. Once a week I would have to de-lime the cell in a 1:5 mix of muriatic acid and water. And remember, I wasn't using any borates those seasons. So now, seeing the absence of buildup in my LQ due to the borates, I can't help but wonder if 50 ppm berated would also prevent buildup on a SWG cell, thus greatly prolonging cell life. Any thoughts?
    13,500 gal
    24 round x 52
    Hayward Dreamline 175 lb sand
    Hayward 1.5 hp pump
    LQ chlorine feeder
    50 ppm borates
    3500 ppm salt (because I like the feel)
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Borax and SWG
    I am on my third season with a intex swg. I do not have build up that I have to clean now that I have added borates. Before I added them, I had to clean the cell about twice a season.
    With that said, it could be that you were running your swg long enough each day that you wore it out (your pool is at the edge volume wise of it's capabilities). How long were you running typically? What cya level were you running then?
    Re: Borax and SWG
    Well when I first got the Intex SWG, I also had a 15' Intex pool... The one with legs, not the inflatable ring. Seems like I was running cya about 40 and running SWG about 4 or 5 hours a day. It lasted the whole summer and I had to clean white growths off the cell about every 4-5 days. I always would clean it before winter storage too. Then the next season, it would work for about a month and then fail with a code 91, despite proper salt level (160 lbs in a 6,450 gallon pool that I took down each fall and set up each summer). Now I have a 13,500 gallon pool. With the SWG I was running it around 7 hours a day and a cya around 60. I also wasn't a TFP'er then.
